Old 04-12-2019, 01:55 PM
2015XDRIVE 2015XDRIVE is offline
Default LOOKING FOR PHOTO OF RAM AIR BATTERY CABLE ROUTING
Anyone have a ram air car that can post a photo of the positive battery cable routing behind the alternator mount to the battery? I installed RA manifolds and wiring harness and having trouble getting cable to battery. Seems to short.
Thanks!:
Old 04-13-2019, 04:58 PM
younggto younggto is offline
No pictures or real world experience but there is a tube that mounts I believe between the block and the motor mount that the positive cable runs through.
Old 04-13-2019, 05:05 PM
TPM TPM is offline
Ames sells the longer battery cable and the heat shield tube that bolts to the motor mount.....I purchased them when I installed ram air exhaust manifolds on my 65 GTO
Old 04-13-2019, 05:51 PM
Yes. I have the tube(heat shield). I need a photo showing the route up the front of the block.
Old 04-13-2019, 07:00 PM
TPM TPM is offline
I ran the battery cable down along the the power steering pump bracket - I bolted a flexible u-hook to the bottom bolt of that bracket and secured the cable to that hook which holds it in place and away from and down under the exhaust manifold (enlarge the picture and you can see the shielded battery cable go through the hook)
Old 04-13-2019, 11:49 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
On 1967 HO and RA cars the positive battery cable was longer and the two starter wires were also longer as they had to travel down the LH front of engine, turn and travel through an oval tube screwed to the LH motor mount to reach the solenoid. The engine harness was unique for these GTOs because of the large exhaust manifolds.
Chris.
ID:	510089   Click image for larger version
ID:	510090   Click image for larger version
ID:	510091   Click image for larger version
Old 04-14-2019, 11:14 AM
Thanks to 60sstuff and TMP for the photos and diagrams! They are exactly what I was looking for.
Old 04-18-2019, 05:14 PM
xsram67 xsram67 is offline
Default xsram battery cable
The ram air battery cable runs down in front of washer reservoir and there is a black plastic cable clamp at that point with a 5/16 screw. It then travels down and behind the power steering lines to the heat shield tube.
ID:	510482   Click image for larger version
ID:	510483   Click image for larger version
