Old 04-18-2019, 09:38 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
Default First Look @@ High Performance Injuns SpeedMaster Heads
Nice thread with lots of pics in the Street Section.
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
Old 04-18-2019, 11:42 PM
Dragncar Dragncar is offline
I have to say, castings do look nice. Now lets see what some CNC programs can do ?
Old 04-19-2019, 07:50 PM
ck67goat ck67goat is offline
Will be interesting to see users feedback about both quality, use and actual performance. Are these cast and machined locally?
67 GTO street car - 428, roller cam, TH400, GV OD, through mufflers Best ET - 11.44. Best MPH - 116
67 GP Convert 428 HO Project Car in process
67 GP Convert 400 (not sure yet if parts car or future project
68 Catalina Convert 400 - all original 135k miles
Old 04-19-2019, 08:14 PM
These are SpeedMaster heads that we are adding to the line up. An affordable alternative to the current offerings. Check out the Street Section for lots of info.
Randy Repp
Old 05-06-2019, 11:27 PM
Default Slice 'n Dice
Why destroy a brand new $700+ head? Because we want to offer our customers Quality and Affordable Reliability. I have more slicing to do and will be publishing the results in an upcoming magazine article.
So far these heads are exceeding expectations and that's exactly what we want to do.
ID:	511731   Click image for larger version
ID:	511732   Click image for larger version
ID:	511733   Click image for larger version
ID:	511734   Click image for larger version
Randy Repp
Old 05-07-2019, 09:53 AM
mgarblik mgarblik is offline
From the first group of pics, I don't see any garbage in the aluminum mix, no inclusions. I would suggest trying to drive out a guide to gauge the press on it. Doing the same with the seats will be more difficult. Looks like adequate material in the head bolt column. Only thing I see in the pics so far is any changes to the spring seat for larger, or more installed height should probably be done with diameter and valve length only. Looks like water is fairly close under the spring seats. Probably wouldn't risk cutting down more than .030" or so for clean-up. Keep up the good work.
Old 05-07-2019, 11:00 AM
slowbird's Avatar
slowbird slowbird is offline
Doesnt appear to have much water flow between center exhaust bowls, that area might get hot and see head gasket issues
Old 05-07-2019, 01:45 PM
There is actually more space there than with the Edelbrocks.
Randy Repp
Old 05-07-2019, 03:41 PM
slowbird's Avatar
I've never seen an e-head cut up but a KRE HP heads have good cooling between center exhaust bowls
Old 05-07-2019, 07:41 PM
Scott Roberts Scott Roberts is offline
If you care to do more testing on the quality of aluminium, send me a chunk of the head.. I will have our lab ( I work at an aluminium casting and exstrusion plant) run it through a bunch of tests...
I will send the results to you and you can do what you want with them..
Old 05-07-2019, 08:57 PM
Thanks Scott! PM me the address and I'll get you some material. This is how we all advance the Pontiac hobby - working together!
Randy Repp
Old 05-07-2019, 09:22 PM
PM sent..
Old 05-07-2019, 09:29 PM
PAUL K's Avatar
PAUL K PAUL K is offline
PM sent..
That's awfully nice of you...I thought being nice was against your beliefs.
Go fast, see Elvis!
Old 05-08-2019, 12:38 PM
I'm not really an asshole, I just play one on the net..
Old 05-09-2019, 10:00 PM
SpeedMaster Heads Quality Update.
We received the band saw blade today so tomorrow I'll be at it again. Slicin' 'n Dicin'
I've learned that with all SpeedMaster products, the R&D and engineering is all performed at their headquarters in Australia. The castings are made in China and the CNC machine work and assembly is all done right here in the USA. So these heads are truly international and many families are getting fed making these heads.
Randy Repp
Old 05-10-2019, 07:47 AM
My experience with Chinese "hard engine parts", is that machining performed in the US with US inspections and machine maintenance greatly improves the finished product. So that is good news. If I was Speedmaster, I wouldn't hide the steps you just found out, I would advertise the information. Another example of a company that can make this production method work is Molnar. Design and engineering in the US, Rough product from China, finish machining and inspection in the US. Need to get some of these heads on the track and street ASAP and really try and "prove them".
Old 05-10-2019, 08:31 AM
That's another reason we are a WD with Molnar too.
Randy Repp
Old 05-10-2019, 09:54 AM
GTOGEORGE's Avatar
Looks like the price is going up 25%!
GTO George
Old 05-10-2019, 10:33 AM
krisr's Avatar
krisr krisr is offline
Yep, Narellan Sydney is their big warehouse now. I did some work for Pete (owner of Speedmaster) a little while back as he wanted to develop an FI-carb like a Holley Sniper or FiTech and I started the R&D project for him after I paired him up with the Megasquirt guys. Should give him a call as I made him a few test throttle body systems and just needed a motor to run them on to v'fy everything. It's taken him a while to get here in terms of quality, but some of the stuff they produce now is nothing like their old 'cheap' gear. Awesome to hear the heads are a winner!
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 05-10-2019, 11:26 AM
GTOGEORGE's Avatar
Let’s see a set of heads on the track first!
GTO George
