Old 06-06-2019, 01:39 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Default Tach cable
Anybody know if big truck speedometer cables might use the same ends as a mechanical tachometer cable? Pictures of some for sale look to be the same, but I can't see the details- whether the ends have the same square drive as a tach cable. I need an 11' long cable for the rear engine lakester, and race suppliers of cable need time to build long cables- not to mention many $$$.
Old 06-11-2019, 09:34 PM
Stuckinda60s Stuckinda60s is offline
Can't answer your question, Jack, but have a suggestion. Speedometer shops used to be pretty common and they made cables. I'd check your area's yellow pages and you might be able to find one or two. If you have a cable, you can use the ends from that to make a new cable. You could probably even solder one together, yourself. Just order the cables on-line.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 06-12-2019, 12:37 AM
242177P's Avatar
242177P 242177P is offline
I *believe* they are, but can't say that 100% certainty. Bought speedometer adapter at a truck parts place before, so there should be some crossover?
Old 06-12-2019, 01:48 AM
Thanks for the suggestions.
Although I haven't really answered my question yet, I ordered a truck cable that's long enough. I'll know soon!
Old 06-19-2019, 02:36 AM
The truck cable was almost a perfect fit. But the magneto-drive end was simply square, lacking the needed "blade". I carefully un-brazed the blade piece from my old cable and attached it to the new one. I won't know if it's okay until I finish the car enough to fire it up.
