Old 06-15-2019, 08:58 AM
Interceptor's Avatar
Interceptor Interceptor is offline
Default Cooling Fan Switch
So I'm looking for a temperature sender that mounts in the stock intake manifold location to turn on the electric fans. Prefer the current configuration where the switch goes to ground when the temp is reached. Any suggestions for something locally available, i.e. Blue Streak, Standard, Napa?
A dual switch would be even better, for High and Low fan turn on.
Something like this, but with 1/2" NPT: https://www.banggood.com/200-To-185-Electric-Engine-Cooling-Fan-Thermostat-Temperature-Switch-NPT-p-1008174.html?currency=CAD&utm_source=bing_pa&utm_m edium=cpc_bgs&utm_content=zouzou&utm_campaign=pa-ca-ele-pc-zouzou&creative={creative}&cur_warehouse=CN
70 GTO Restomod -- 400/200-4r, nothing to see here
70 Firebird -- 455/400
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 06-15-2019, 09:13 AM
Although I guess I could re-wire the existing relay for 12v input.
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 06-15-2019, 10:52 AM
STEELCITYFIREBIRD's Avatar
Get your eyes on a paper copy of standard ignition illustrated parts guide, the online one doesn't have specs.(that I could find)
The one we had in catalog form (20 years ago)had thread size, temp setting, etc.
Any good parts store and parts man still has one in their bk rack!
Old 06-15-2019, 11:00 AM
You really should use it to trigger a relay, fan is a pretty heavy load, especially when it starts.
Old 06-15-2019, 11:22 AM
http://www.pageturnpro.com/Four-Seas.../index.html#20
Go to FS #'s And TS # following, find pigtails to match in pages following if queer.
Old 06-15-2019, 02:38 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Do yourself a favor an install a fan controller. More flexible in control and reduces the current.
Old 06-15-2019, 03:11 PM
Lee's Avatar
Lee Lee is offline
Agree. I've been using Brian Baskin's controllers for the last decade. Used close to a dozen now, zero failures. It usually takes a couple weeks to get one, but worth the wait: http://www.dccontrol.com/selector.htm
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 06-15-2019, 11:48 PM
That is what the grounded circuit triggers
Sent from my SM-G930W8 using Tapatalk
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 06-16-2019, 03:09 AM
fastekibeast fastekibeast is offline
Highly recommend Harris Performance Controls. Made in Canada
I have one of his dual fan wiring kit #102004 it works like a charm!! Worth every single penny.
Janne
Old 06-16-2019, 06:00 AM
steve25 steve25 is offline
I would check out the Stewart Warner line of parts.
Old 06-16-2019, 08:41 AM
Sorry I misunderstood your description.
Old 06-16-2019, 12:21 PM
ponjohn's Avatar
Agreed.
I was thinking of making one with more flexibility in temp adjustment etc.
Never got around to it.
