Old 10-17-2019, 11:26 PM
nbn nbn is offline
Default Column shift 73 Formula
We are getting ready to jump into the restoration of the steering column for the Formula.
With this being a column shift car, how difficult will it be to find replacement pieces if needed?
Old 10-18-2019, 11:26 PM
Formulabruce's Avatar
I have one if you need it. $50.00 plus shipping , which could be 80 bucks.
Old 10-19-2019, 10:31 AM
bird72's Avatar
bird72 bird72 is offline
/\ Good Mr FBruce! I was feeling bad I junked one a couple years ago
72 Bird
Old 10-19-2019, 11:54 AM
77 Canamman's Avatar
As soon as I collect all of the parts I need to convert, mine will be chucked too.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 01-25-2020, 09:20 PM
nbn nbn is offline
So life has gotten in the way and it's taking me longer to get things moving than hoped for, again.
We pulled the column all the way down, cleaned and greased bearings and ordered pieces as needed. The column has been painted and things are going back together.
What I have figured out to this point 1) someone has been in this column previously, 2) that same someone should be slapped for throwing out pieces 3) ignition lock cylinders seem to be different on column shift cars
Monday I'll be sourcing a lock plate to replace one that is missing along with a broken buzzer contact. Ill also be searching for the correct ognition lock.
ID:	530007   Click image for larger version
Old 01-25-2020, 10:44 PM
bird72's Avatar
It looks really nice.
72 Bird
Old 01-26-2020, 08:21 AM
I am curious to know what is different with the lock cylinders. I have installed several in both column and floor shift columns, and they were all the same 1970-up. 1969 used a much smaller cylinder.
Per the partsbook, they are all the same regardless of shifter location.
Old 01-26-2020, 09:08 AM
ladytata's Avatar
ladytata ladytata is offline
I have a 70 fb column shift if you need any pictures to compare to
Old 01-26-2020, 10:31 AM
Brewster's Avatar
Brewster Brewster is offline
Love those oddities like a column shift muscle car. Im a little bias though
Old 01-26-2020, 10:43 AM
nbn nbn is offline
I've posted a picture of the original and replacement cylinders. The replacement has a shoulder that is preventing the cylinder to seat into the column properly.
Old 01-26-2020, 04:17 PM
nbn nbn is offline
77Canamman
Thanks for questioning my post. I went back and second guessed myself after your statement.
I had the lock plate peg gear one tooth off. Once that was repositioned, the cylinder dropped in and operated correctly.
Now to order a replacement buzzer spring and a lock plate and this part will be done.
The Following User Says Thank You to nbn For This Useful Post:
