Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-26-2019, 02:52 PM
Ram4king's Avatar
Ram4king Ram4king is offline
Default Pontiac 400 stroker shortblock
I have a 1975 Pontiac 400 engine code ZJ out of a Trans am I think that was built into a stroker with a Cast 455 crank,studded mains,arp bolts,eagle rods and JE srp forged pistons,alum timing chain cover and thicker balancer. A few thousand miles on it. I looked it over pretty good. The only issue is cylinder #5 has a little pitting in a small spot from water laying in it I guess.
I think it might just need a little honing or leave it alone. Up to the buyer. 1500.00
ID:	525464   Click image for larger version
ID:	525465   Click image for larger version
ID:	525466   Click image for larger version
ID:	525467   Click image for larger version
Old 11-26-2019, 04:03 PM
mysticmissle's Avatar
what is block casting number?
Old 11-26-2019, 04:16 PM
Ram4king's Avatar
500557 is the casting
Old 11-26-2019, 04:22 PM
Ram4king's Avatar
Originally Posted by Ram4king View Post
I have a 1975 Pontiac 400 engine code ZJ out of a Trans am I think that was built into a stroker with a Cast 455 crank,studded mains,arp bolts,Childs and Albert aluminum rods and JE srp forged pistons,alum timing chain cover and thicker balancer. A few thousand miles on it. I looked it over pretty good. The only issue is cylinder #5 has a little pitting in a small spot from water laying in it I guess.
I've added that the engine has Childs and Albert aluminum rods in it.
Old 11-26-2019, 04:46 PM
straycat's Avatar
straycat straycat is offline
Location? I'm interested. Eagle rods or Childs & Albert. Sure it's a 455 crank in a 400?
Old 11-26-2019, 06:41 PM
Ram4king's Avatar
Yes sir. Checked every number today. Advertised it a little too quick that's all.
I've been to your house and bought a 390 rear from you years ago.
I'm also selling the aluminum heads off this engine in a different ad
Just call the number listed if you want to talk
Old 11-26-2019, 06:42 PM
Ram4king's Avatar
Also I'm down in philly just off I95
