Is there a OD manual transmission that is a direct swap in a ‘71 GTO?
The car is the GTO in my signature. I currently am running 3.90’s in an GM 8.5. The 3.90’s were fun when I was living in the city, but now living in a rural area I’m considering dropping an OD transmission in. I don’t want to hack up my transmission tunnel and such. Soooo......is there a “bolt in” OD manual transmission out there?
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
http://forums.maxperformanceinc.com/...d.php?t=836613
There is tons of info on here. TKO-600 with a .64 od for highway cruising. Try the search on the form and start reading. Charles |
4L80 manual-shift is in my 4-Speed 68 GTO. Drop-in but come on:
Shorter driveshaft, move crossmember back, Block adapt-plate ($58), Yard-pull 4L80s for $70 or so Grafted mech Speedo, Vacuum Modulator added, Stock converter for now (like it) Clutch pedel unlockes converter (toggle bypass for daily driving) I have Column shift for PRND, then 4-spd shifter on 4L80 tail. Auto Floor-shift car would be dramatically easier Compare with TKO-600 install details. |
a gear vendors probably would require the least modification.
I put a TKO600 in my 69 GTO. You will not install it correctly in a 69, nor I suspect a 71, without opening up the tunnel. I have a loooong install thread on here that details my experience. That said, I’d hack it up again as a manual OD Trans is a fantastic thing. http://forums.maxperformanceinc.com/...ghlight=TKO600
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 12-25-2019 at 12:00 PM. |
I think the Richmond 5 speed OD fits without cutting.The OD version has only been around a few years so hard to find a used one.Tom
The spec provided has a mistake,it says 10 spline input,it is 26 and the price includes the Long shifter.Tom
Oh, and my GTO has the factory counsel. Would it still work?
I don’t want to cut this one and If I can’t do an overdrive I would seriously consider just putting the 8.2 back in it and selling it, then buy a non original car to play with Thanks
I have a Richmond OD for my '66 and started to put it in the car, but dyno schedule had me pulling the engine before I could get it in the car. The Richmond I got is a 6 speed - found used at Carlisle for ~$1700. Since it was used, the shifter bracket ws already mounted to it, and that was keeping me from installing it in the car (engine would not lower down enough without taking off drivers side header). Engine is no out of the car and I'm making a bunch of changes to the car before re-installing.
I have the tailshaft off the trans and haven't had time to work on removing the shifter bracket. I think with this bracket removed, the trans will go in with minimal trimming. I did trim the bit of floor that was inside the shifter porch - about 1.25" at the top down to about .5" at the lower left corner. My car has an original floor and I refuse to cut anymore that the small amount I have trimmed. Supposedly the 5 speed OD trans has the shifter about a half inch forward of this 6 speed. That was from a Richmond tech. I don't have one to compare to. I like the ratios of the 6 speed. He did tell me they are bringing back the Richmond 6 speed soon.
Tod Hoffmann 1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd 1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler 1996 Chevy K2500 ECSB 'Poopy' 2002 Honda VTX1800C 2016 Cadillac CTS Premium My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826 |
So guessing 2nd gen F bodies have a larger tunnel than the 68-72 A bodies? I know there's no problem putting a TKO600 in a 2nd gen F. I also am using drop body bushings, still fits.
David Jones - Guessing the area of contact is the 'square' upper part of the case that hits the rounded part of the top of the tunnel? Trying to get an idea of where the issues are for future reference. I've heard some talk of a 'template' that's included in some TKO 'swap kits' for 68-72s, and that it's fairly straight forward, and can be done without too much effort or fab skills. Curious if anyone has info on that as well? Think I saw someone mention a Silver Sport kit that was like that? Also understand that the carpet and console hides any mods that are required? .
Option "B" is to change your diff to 3.08's or 2.93's and run a M22Z.
No driveshaft changes, same shifter, console, etc. Only issue I had was the yoke I had did not fit, Paul sent a new one and it fit perfectly. The gear spread is more as it covers a 0.82 OD gear spread but in 4 gears, no issue at all with a torque heavy 440 Pontiac. https://www.5speeds.com/newm22.html |
Another option would be to swap your 3.90 gears to 2.73 (same posi carrier is used for both gear sets) and find a non-OD Richmond or Doug Nash 5-speed, they can still be found used for reasonable prices.
One advantage is the lower driveshaft speed in 5th with 1:1 gearing, the driveshaft would be spinning extremely fast with an OD and a 3.90 gear. Minimal to no tunnel mods to install, shifter position is a litter further back than stock but it can be moved forward with a little modification to the shifter mounting plate and shift rods. I have a Doug Nash 5 speed with Long shifter that was originally in my old ‘64 GTO when I bought the car from my friend. I was able to move the shifter forward and down enough to make it work in a ‘69 Firebird with the stock console, only very minor trimming of the shifter hole was required. Also had to move the stick toward the drivers side by about an inch using a fabricated spacer between the stick and shifter mechanism, came out looking factory.
I originally split the tunnel on the passenger side just enough to get the TKO in there and realized that was a waste of time since I was going to have to fill a hole, making a bigger one wasn’t a big deal. Keisler basically wanted you to cut the whole top of the tunnel out before you got started. I felt my way into it. I found all the Abody sites a valuable resource, especially the Chevelle sites. My understanding is a 4spd console will fit. I’ll also add that the engine mounts were fairly fresh, the trans mount was new and the crossmember isolators were new. The body mounts were about 6-8 years old.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 12-25-2019 at 07:27 PM. |
Be sure to leave room in the tunnel to pull the trans if necessary.Would hate to have to take the tunnel apart to get it out.When we did my 63 tempest we made the tunnel removable.Tom
I'll say it again, you do nice work! .
Tom, getting the trans in and out is straightforward.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Keisler's RS600 trans was a bolt in with my 70 GTO but unfortunately they are no longer in production. Keisler had many business struggles that led to the close of his business. That is a sore subject with many I will not get into here. With the exception of occasionally popping out of reverse it has been a good product. No tunnel mods and the factory console fit. Only had to move the trans crossmember and have shorter driveshaft made. The Richmond with 1:1 5th and higher rear gear is an option many of the local guys have used successfully in GTOs.
Silver Sport bought the Tremec conversion portion of Keisler's business and still offers the kits. American Powertrain is operated by former Keisler employees. They had stated at one time they thought the TKO could be installed in the 68-72 A-Body if everything was just right. That included new body bushings and alignment. With the TKO case width it doesn't really fit A bodies without mods. 2nd Gen F-bodies have a much wider tunnel.
1970 GTO 400 Atoll Blue, PS, PDB, A/C Was M20 4 speed, now has Keisler RS600 5 speed. |
