Old 01-01-2020, 04:59 AM
64speed's Avatar
64speed 64speed is offline
Default Removing rag joint from steering box.
I loosened the screw on the clamp and tried fitting a puller onto it but I couldn’t get one on there. I have beat this damn thing with a hammer till I am red in the face and I got it to move an 1/8 of an inch maybe. Anybody got a trick to getting it off?
Old 01-01-2020, 05:52 AM
Old Goat 67's Avatar
You must remove the bolt on the clamp completely. It will slide off then.
Old 01-01-2020, 06:03 AM
dataway's Avatar
dataway dataway is offline
And ... buy a new bolt now
Old 01-01-2020, 08:53 AM
Yes the bolt must be fully removed, it fits in a shallow groove in the shaft for locating the rag joint properly. I also agree about buying a new bolt.
Old 01-01-2020, 09:20 AM
64speed's Avatar
I have a whole new joint that came with the ididit column package
Old 01-01-2020, 09:27 AM
Grand73Am Grand73Am is offline
Unfortunately, since you beat on it, the upper seal on the steering box will probably leak now.
Steve F.
Old 01-01-2020, 04:36 PM
STEELCITYFIREBIRD's Avatar
Remove bolt, buzz off with air chisel
Old 01-01-2020, 04:40 PM
geeteeohguy's Avatar
I agree. The procedure is to remove the bolt so that the coupler can slide off of the splines. Beating on the coupling with the bolt in place = Bayad, Mmkay?
Jeff
Old 01-01-2020, 07:13 PM
Tom Vaught's Avatar
Boost Engineer
There are Pontiac Shop Manuals that explain how to take things apart.
Do you own one?
Tom Vaught
Old 01-01-2020, 07:48 PM
NeighborsComplaint's Avatar
Youtube
Triple Black 1971 GTO
Old 01-03-2020, 11:52 AM
Johnny99's Avatar
Johnny99 Johnny99 is offline
After removing the bolt I've always used pry bar/screwdriver between the ears to open the clamp up slightly
NOT a GTO. 1965 LeMans 455
Old 01-03-2020, 12:32 PM
Tom Vaught's Avatar
Boost Engineer
Same here and use a small hammer and some "Penetrating Oil" to help get it moving on the splines.
Tom V.
