Old 01-22-2020, 09:31 PM
Mike Davis's Avatar
Default Turn Signal Switch
I have been chasing a problem for a while now on my 66 and think I narrowed it down.
Bought a "ebay" turn signal switch listed for the 66 and have not had brake lights or turn signals since I put the car back together. I believe after the power goes through the brake light switch it goes to the turn signal switch.
So my big question is where to buy the correct turn signal switch?
Is the one M&H sells correct?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 01-23-2020, 12:23 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Hi Mike,
Just a suggestion. There are a couple NOS turn signal switches in the GM box on eBay.
A little expensive, but they are the real deal.
I have a spare switch just in case one of my cars needs one.
Chris.
ID:	529585   Click image for larger version
ID:	529586   Click image for larger version
Old 01-23-2020, 08:33 AM
Mike Davis's Avatar
Thanks, do you the best way to tell an original? Are they all blue and white? The one I bought was supposed to be a GM part.
Issue is I have front turn signals and have all running lights, just no brake lights and rear signals. Fuses are good and brake light switch is good.
421 CID
Old 01-25-2020, 01:22 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Try manually grounding the rear lights. Just a test to rule out the switch. Changing stuff in the column is a pain.
........I'm just learning as I go.......
Old 01-25-2020, 09:13 PM
Mike Davis's Avatar
Lights have a separate copper ground to the chassis.
Ordered a Original Delco/GM switch today. Have the column and dash out so I might as well replace it.
421 CID
Old 08-25-2024, 09:43 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Hi Mike,
I know this is 4 years old but I was wondering if a different switch took care of the problem. I just installed a Shee-Mar switch in my 67 and have no brake lights or hazards but the turn signals work fine. My symptom was the brake lights wouldn’t work when the left signal was on, moving the lever up just a bit made the brake lights comeback on so I figured the switch was worn.
Did an OEM switch fix yours?
Old 08-25-2024, 01:50 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
I had the same problem this week (on our '69) with the lever not returning all the way on LH turns causing the LH brake light to not work. Move the lever up and everything is fine. This was a one year old American Autowire switch. I replaced it with a AC-Delco switch yesterday and it works much smoother. Although I did have to swap the plug because it was different than my American Autowire harness. The old switch is in the pic, what happens is the metal shaft circled in red slides back and forth and caused to much friction as it wears into the plastic. The red circle is LH signal, the other end is RH The AC-Delco switch has less tension in the center and slides smoother so maybe less wear.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
The Following User Says Thank You to HoovDaddy For This Useful Post:
