Old 03-13-2020, 09:02 PM
Omni Omni is offline
Default 670 head question
Good Day All
I'm replacing the 093 heads on the wifes 66 389 with a set of 670's.
From what I've been able to piece together I will need to replace the rocker/nut/fulcrum, push rods and the valve covers due to the different valve geometry.
Is there any other parts needed? Any advice on brands?
The car is used for cruising only.
Thanks to all who respond.
Omni
Old 03-13-2020, 11:05 PM
400 4spd.'s Avatar
Sounds to me like you have it covered. I do know that failing to swap out the 389 valve covers for the taller 400 style will not be pretty.
Old 03-15-2020, 01:18 PM
PontiacJim1959 PontiacJim1959 is offline
Originally Posted by Omni View Post
Good Day All
Omni
Read this: https://www.gtoforum.com/threads/670...estion.136633/
Old 03-15-2020, 04:05 PM
See my answer to "push rod" question that you asked. You can use your old rockers if they are in good condition.
The Following User Says Thank You to Goatracer1 For This Useful Post:
