Hey Gas I’ve been trying to convert my drums to disc on my 70 Catalina that I have contact the scabird no luck I’ve contacted rice stuff no luck can anyone help
U know that really did not help me but ok thanks Sent from my iPhone using Tapatalk |
I posted that I have contacted them and right stuff and neither of them have anything Sent from my iPhone using Tapatalk |
Disc brakes were an option on 70 Pontiac Catalinas. Why go aftermarket?
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
So what do I do to change it from drums to disc Sent from my iPhone using Tapatalk |
I would use original parts too. I would get the spindles, caliper brackets, rotors, proportioning valve, and lines to the proportioning valve all used. Then I would buy calipers, pads, rubber lines and master cylinder new. Should be basically a bolt on job.
Can u guide me in the right direction as in where to call cause autozone orileys Napa says no on spindle and rotors Sent from my iPhone using Tapatalk |
Thanks I appreciate it I have found everything except for the spindles Sent from my iPhone using Tapatalk |
Well you’re going to need to source those from a parts car. Just get the pads, calipers, rubber brake hoses and master cylinder from a parts house like Napa. You’ll need the spindles, rotors, caliper brackets and proportioning valve off of a parts car. You might post a want add in the forum for those used parts.
You should be able to buy the spindles from Summit.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
They do not list those. As stated, very low demand - best to contact one of the big yards, like French Lake in MN and get a OEM spindle.
Where did you find the rotors? They haven't been available after market for a long time. You might want to contact Frank:
https://www.facebook.com/search/top/...epa=SEARCH_BOX
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
How do I contact frank Sent from my iPhone using Tapatalk |
No spindles on summit but they have everything else Sent from my iPhone using Tapatalk |
Have you checked with [email protected] for the spindles?
400 Lemans
I have an alert that’s u posted something and I can see it in my email but not on here is there anyway u can get me that contact for the brackets u showed me Sent from my iPhone using Tapatalk |
https://www.facebook.com/marketplace...4119882019282/ Not mine but they may work for you. There rusted but the spindles would clean up.
