I have been looking for a bell housing dowel pin puller and haven't had any luck. I find plenty of pullers, but they don't go up past 1/2". GM dowel pins are 5/8". Does anyone know of a source? I need to install some offset pins for bell housing alignment.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Hole open on the back side to tap them out?
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I drilled and tapped mine for a 3/8 bolt and used a slide hammer
Illinois Outlaw Gassers 6.27@107 9.97@131 |
If its a blind hole - sometimes you can use a thread tap.
Just keep on turning it as it bottoms out in the hole and the dowel will thread its way up the tap, and out. Use some PB Blaster spray ahead of time, to start with. Its one of the ways we get old starter bushings out of bellhousings on older model VW Diesels. They are a pressed fit into a blind hole of an aluminum casting. |
Weld a bolt to it and slide hammer it out.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 6.0L LS single turbo, 8.85 @155 mph 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.03@171 mph 2009 G8 GT |
goodson makes a puller with a 5/8 arbor
i just drill a hole down center and tap 1/4 or 5/16 use a threaded rod and a nut and a spacer that fits over pin and is longer than pin and turn nut and they pull right out
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
i was thinking of a hollow dowel
- my fault if its not a hollow one. Been so long since i held a Pontiac bellhousing i can't even remember what type of dowels are in them. Some really good suggestions by these other guys. |
Put a nut over it and weld it on, put some heat on it, then hit it with some WD40 or the like, it will twist right out.
Thanks guys for all the tips. I appreciate them but I really would like to buy an actual puller if possible. My machine shop has one made by Snap On that work's on 5/8" pins but it's really pricey. I'm always having to pull the pins and replace them with longer ones when we dyno engines, or I use an adapter or mid-plate. All the suggestions above to get the pins out destroys them or is fairly time consuming.
Still looking for an actual reasonably priced puller if anyone knows or has one.
Gary,
Procure a cheap slide hammer w/ 1/2" threads. Use the attached conversion coupling nut. drill the 5/8" side out to fit over dowel. drill one (or2) sides for set screw (s). I you need a longer one, you could weld one 1/2" coupling nut to a 5/8" coupling nut. Drill 5/8 coupling nut and tap for set screw (s)... Whallachinga….cheap dowel pin puller! https://www.mcmaster.com/91072A333 |
| The Following User Says Thank You to Bnick166 For This Useful Post: | ||
This is a pretty cool idea! Sounds like it will work, and be usable multible times. I think I'll try it. Thanks to everyone for the responses!
It is a blind hole, no access from the other side (as the oil passages are on the passenger side) and the drivers side has casting material supporting the bellhousing bolt hole on that side as well as the Starter Mount ear of the block.
The dowels on the 3 blocks I looked at all had a very short exposed length before the taper so getting a gripping tool on the dowel would be very difficult. Drilling/Tapping the dowels is the only choice. I personally would prefer to use a drilled and tapped dowel and then a circular ring larger than the dowel to allow the dowel to be pulled from the block using a washer, bolt and breaker bar/socket. Too many chances to break the block using the bottom of the dowel hole as the "force point" to force the dowel from the block bore. Richie H. has the right method. Tom V.
| The Following User Says Thank You to Gary H For This Useful Post: | ||
Just post up the number of Pontiac Engines, not chevy, ford, etc that he has used this puller on in the last 6 months.
Not saying that the snap on puller will not pull the dowel pins on GM engines. So how many Pontiac engines has he dynoed in the last 6 months. Then you can say I am wrong. One or two isn't a representative size as the dowels may have already been removed at least once prior to your dyno session. Tom V.
I usually use a length of 1/4" steel strap with a hole drilled into it and MIG weld it over the dowel, the heat from the welding makes it easy to just twist and pry the dowel out.
Happy for you, good day
Tom V.
Question, installing a .100 mid plate. Can I leave the stock dowel pins as is ?
I would say maybe...when I went to a Lakewood scatter shield with a .125 block plate I had to change to longer dowels but it was close.
I agree, I just installed a .100 adapter plate for a Pontiac to 700 R-4 conversion and I decided to go ahead and put the longer dowels in. It's a customers car and I'd rather be safe than sorry with it.
