Old 12-22-2020, 11:18 PM
68 Caretaker's Avatar
68 Caretaker 68 Caretaker is offline
Default Correct Inner fender hardware
Got a question for the 68 experts. After going through some old GTOAA judging sheets from the previous owner, I believe my inner fender to fender bolts are wrong. Anyone have any pics of originals? Thanks.
ID:	556724   Click image for larger version
Clark Lumsden
68 GTO 400 HO 4 speed ,Nightshade, ivory painted top, parchment.
72 Chevelle SS 454, PSMCDR 13.21@106
73 Buick Riviera Stage 1, PSMCDR 14.54@93.
70 GS 455, 4spd. PSMCDR 13.94@101.
69 GP SJ 428, TH400, 3.23. PSMCDR [email protected].
Old 12-23-2020, 03:52 AM
Scott Thelander's Avatar
looks like door hinge bolts
and
windshield washer reservoir delete ?
welcome to the forum ...
Scott
Old 12-23-2020, 06:09 AM
dataway's Avatar
dataway dataway is offline
Pretty sure they should be much shorter and pointy. Usually they have bits of rag stuck to them that gets ripped off when you clean the inner fenders
Old 12-23-2020, 10:20 AM
and
Scott
I think the bolts are generic body shop hardware. I found 4 nuts in a box of leftover restoration parts that might be the right ones. The washer reservoir is there.
ID:	556740   Click image for larger version
Clark Lumsden
Old 12-23-2020, 10:25 AM
I found 4 nuts in a box of leftover restoration parts, but they are different from yours. I wonder if different assembly plants used different style hardware or there was a different supplier? Thanks for the pic.
Clark Lumsden
Old 12-23-2020, 10:48 AM
Yeah, they should be the shorter, sharp pointed ones that dataway shows. The nuts you have on there now are ok. Just change the bolts and I think you'll be good. I've never seen the type you found in the box used in that location. Plenty of other locations but not there.
Old 12-23-2020, 12:31 PM
dataway's Avatar
Yep .. those clips you found are way too light duty for that location.
The clips you have installed now look to be generic re-pop clips used in various locations. The originals are pretty big.
Old 12-23-2020, 01:05 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Is that Paint Code V - Nightshade Green? I have two NSG cars - my first ever GTO is this color.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 12-23-2020, 01:19 PM
Kurt, it is and it's one you're sure to have seen. Check the op's intro thread.. https://forums.maxperformanceinc.com...d.php?t=846755
Sent from my moto g(6) play using Tapatalk
Old 12-23-2020, 08:47 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Hard to tell their size, but at first glance they look like the ones found all over the core support
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 12-23-2020, 10:03 PM
Well guess what I found? 4 nuts on the radiator support belong on the fenders, so I changed them out with the 4 that I found.
ID:	556765   Click image for larger version
Clark Lumsden
Old 12-24-2020, 06:50 AM
68ragtop's Avatar
Seeing your going after detail correctness, you can purchase a Gates Power steering hose that does not have that darn ugly restrictor crimped in the center.
We had a thread on that a number of years ago. At some point they starting producing the pressure hose with that restrictor, but the orignal 68's never had it.
Gates part number 354730 is a chevy truck hose that is the same, but without the restrictor. Not an exact duplicate of the original as almost nothing is,
but is the next best thing & is a very inexpensive improvement
89 Trans am GTA
Old 12-24-2020, 11:26 AM
Thumbs up
Thanks for the tip. I ordered one this morning. That was one of the items on the judging sheets from GTOAA that he got dinged for.
Clark Lumsden
Old 12-28-2020, 01:34 PM
The unrestored 69 GTO's and LeMans' I've come across over the years use either of those style nuts to hold the inner fenders to the fenders. I never really studied what the pattern was to see if it was an early late thing, or a plant thing or just different suppliers.
Old 12-28-2020, 11:45 PM
Well, after my last post, I found some pics of an 18k mile 68 LeMans. This car had 4 of the style that I found in the box of extra parts holding the inner fenders to the fenders. I’m wondering now, if the ones that I changed out from the radiator support should have stayed on the radiator support? I found them under the 2 front fender bolts on each corner at the top of the support.
Clark Lumsden
Old 12-29-2020, 07:46 AM
68ragtop's Avatar
There's no doubt that many of these clips & screws have been swapped around from where they should be. When you think about the assembly lines in 68, those guys didn't see correctness they way we do today. Running low on specific clips & swapping them out for something else to keep things moving until break time wasn't unheard of at all. No question that happened & has been discussed on this site quite a bit
My late father in-law had a 68 lemans he ordered new & became my parts car after sitting in a very poor storage arraignment from 1982 - 2001. He never messed with the car from original. While the car was an un restorable rust bucket, it was extremely helpful in the restoration of my GTO as a guide to keeping things correct. There were several things on that car that were original & not what you normally see. For example it had two different sets of bolts holding the quarter glass covers in place. left & right side were completely different. Also had much longer bolts holding the front valance on. Still have all the pictures of that stuff somewhere.
I think keeping the hardware that a car had in place from the factory is very cool. It's what preserving & restoring the cars is all about. Also makes for great discussion as well! But if your not 100% sure its original, I would just install the hardware that was most commonly found on these cars.
While I am very happy my 68 is finally finished, I really miss all of the research on stuff like this.
89 Trans am GTA
The Following User Says Thank You to 68ragtop For This Useful Post:
Old 12-29-2020, 08:06 AM
68ragtop's Avatar
Started browsing through some of the old pics & I have & found another example. These are the hood hinge bolts. I do not know which where in the fender, & which were in the hood, but you can see there are three oddballs. Or, 5 oddballs depending on which ones were supposed to be installed
if the bolt bin is running low on the factory floor, I cannot imagine anyone caring which bolt was used in this case.
89 Trans am GTA
Old 12-29-2020, 10:51 AM
My rule of thumb on the pointy vs. squared off bolts is I like the pointy type if they involve anything that has to be flexed into place...fenders, valence panel, etc.
Old 12-29-2020, 05:48 PM
Kenth's Avatar
Kenth Kenth is offline
Here is the screw used for 1970 GTO, may be the same for 1968?
#3960314 size 5/16-18 X 13/16, uses nut #9789994 and a washer at screw head.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 12-29-2020, 08:23 PM
68ragtop's Avatar
Mine are the same size/shape, but course thread. Not sure if that changed at some point? Both my parts car had GTO had the course threaded bolts. I can take some pics too.
89 Trans am GTA
