Old 02-02-2021, 11:27 PM
Goat1967455 Goat1967455 is offline
Default street/strip 455
i have a 455 35 0ver with srp piston flat top with 5 cc reliefs stroker motor # 16 heads crower solid lifter cam 60310 looking to go to ede round port heads 87 cc 310cfm tired of race fuel want to run pump gas. question waht cc dish piston will i need to be able to run 93 octane in it ./
Old 02-02-2021, 11:38 PM
firechickenman's Avatar
firechickenman firechickenman is offline
You should be fine with the SRP flat tops and an 87cc chamber. I'm running the same pistons in my .035 over 455 (463) with 80cc chambers in my E heads on 91 octane. With zero deck, mine comes out to 11:1
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 02-02-2021, 11:54 PM
JLMounce JLMounce is offline
You should be good to go with the 85cc chamber heads. Be somewhere in the neighborhood of 10.5:1. Depending on tuning and cam choice you may be able to run mid-grade.
-Jason
1969 Pontiac Firebird
Old 02-03-2021, 06:54 AM
steve25 steve25 is offline
What are you running for a Intake Manifold and what rear gears are you running?
Old 02-03-2021, 08:42 AM
Gary H's Avatar
Gary H Gary H is offline
I've built quite a few engines with the 5 CC pistons and 85-87 CC aluminum heads. Most have the 236/242 hyd. roller cam in them and run fine on 93 octane fuel. No hint of detonation at all.
Old 02-03-2021, 09:47 AM
Cliff R's Avatar
Cliff R Cliff R is offline
The heads on my 455 are KRE's with 76cc chambers. Calculates out to 11.3 to 1. Been fine on a straight diet of pump gas now for quite a few years. The cam is a big player here, duration, LSA and intake closing point and overlap can make or break that deal.......Cliff
Old 02-03-2021, 07:05 PM
Formula8's Avatar
Formula8 Formula8 is offline
Loved the 60310 when I was running it in my flat top 463 with big chamber KRE D ports. That motor ran fine on 93. I am considering swapping out the OF and going back to the 60310 in my current engine.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 02-03-2021, 07:29 PM
Half-Inch Stud's Avatar
compr calcs
455 +030 .005" proud. 0deck .023" in the hole
5Cs 98cc __11.93:1 __ 11.79:1 ___11.19:1
48s 78cc __9.88:1 ___ 9.79:1 ____ 9.39:1. per wallaceracing.com
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 02-03-2021, 07:55 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Interesting.
XE284 HFT 284/296 - 240/246 - .507/.510 - 110 ( not a favorable reputation here)
60310 SFT- 284/288 - 240/248 -.477/.501 - 112 - lash - .022 / .024
Old 02-03-2021, 08:30 PM
4dblnkldude's Avatar
XE-285 with 1.65 rockers, 85cc e heads that roll 310 cfm. Exactly 10.85:1 compression with KB hypers. Loves 93 octane. 37* total timing. You'll be fine!!
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 02-04-2021, 11:51 AM
i82much's Avatar
i82much i82much is offline
tell us about the car, maybe it’s got some gear, a manual trans, and/or manual brakes. i want someone to talk you into a 290b6 so you can post a youtube link to your car idling and I can watch it.
Old 02-04-2021, 12:18 PM
Steve C. Steve C. is offline
The combustion chamber design will also have a effect on the situation.
Of interest, how combustion chamber design relates to engine performance....
https://www.hotrod.com/articles/0209...stion-chamber/
Old information here:
Old 02-04-2021, 12:43 PM
grandam1979 grandam1979 is offline
The calculator I used comes up with 10.65 with a .028 head gasket with .000 deck. Just for fun I did it with .000 for head gasket it was 11.31
Old 02-10-2021, 09:52 AM
Running torker intake 373 gear 3000 stall
Old 02-10-2021, 09:53 AM
373 gear auto 3000 stall torker intake
Old 02-10-2021, 09:55 AM
Torker intake 373 gear 28 inch tall tire 3000 stall
Old 02-10-2021, 09:57 AM
Sorry took me so long get back could you tell me more bout cam your running
Old 02-10-2021, 02:24 PM
Sure, it's a Comp Cams custom solid roller with their XE Street Roller lobes 4878 and 4879. 266/272 duration @ .050 with .398" and .404" lobe lift (works out to right at .650" net lift with my HS 1.65 rockers) on a 110 LSA installed on at 105.25 ICL.
This is my second cam with the Comp XE Street Roller lobes. I've been very happy with them. They seem to be very easy on valvetrain parts and don't require a lot of spring pressure.
'68 Firebird
