Old 06-17-2021, 07:01 PM
bajagold70's Avatar
bajagold70 bajagold70 is offline
Default Cameo White Welting yellowed
Short of replacing the welting, is it possible to safely clean the welting? Its sticky and yellow/brown in spots. Its an untouched 24k mile '78 and I would rather not replace if i can clean it up a bit. Any experience out there ?
thanks!
Old 06-20-2021, 10:10 AM
Warren Seale Warren Seale is offline
The plastic is deteriorating which is causing them to yellow and become sticky. If you try to paint them it probably won't hold up due to the degrading plastic. It's best to get new welting and have it painted. There is also a guy that sells colored welting as well for the more common colors.
79 T/A,WS6,403,A3
96 T/A,WS6 (#1344) ,M6
72 442,W30,A3
96 Vette convertible Grand Sport (#713),F45,M6
13 Vette 427 convertible (#1425),Z30/Z25,M6
Old 06-20-2021, 10:39 AM
MUSLCAH MUSLCAH is offline
I painted mine…little scuff of scotch bright…..wipe with some cleaner….and still looking fine ,5 years later
Old 06-23-2021, 02:08 AM
todden8 todden8 is offline
What paint did you use?
Old 06-23-2021, 06:00 AM
RamblerRacer RamblerRacer is offline
I would also use a little spray on adhesion promoter.
JT
Old 06-23-2021, 08:32 AM
My GTO is code 11 Monteago cream….I have some single stage with activator…and dusted on a few coats ….much faster and better than cleaning it….mine were out of the question for cleaning. Plus they are inside and see no wind or weather….you don’t have to ovah think this stuff.
