Is there a way to install passenger header without removing oil filter housing? Go higher with engine? Already tilted engine pretty high but oil filter housing is in the way. Pain in butt to install housing with headers in the way, Thanks!
Sent from my LM-Q710(FGN) using Tapatalk |
I've always removed the oil filter housing. I don't think you're gonna get around it.
I agree, was hoping for a miracle
![]() Sent from my LM-Q710(FGN) using Tapatalk |
It's not too bad. A little bit of a pain getting on the three bolts. Pontiac headers are sooo much fun!!!
Used Hedman Husler headers in my 1967 GTO. They are made in 3 pieces on each side and go on with no problem at all.
Yup same here.. have 24 years on them so far and still awesome
9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches.. |
Interesting. I did have Doug's D-port in a '64 GTO (Swapping to LS now). NBD to do the oil filter housing. The Doug's quality is worth the effort.
I already have the Doug's headers so looks like I will have to remove the oil filter housing. Interesting that Herman does a 3 piece header, any issues with leaks?
