Old 10-24-2021, 07:57 PM
duke455's Avatar
duke455 duke455 is offline
Default 2 gen 8 point roll bar
What the best 8 point roll bar out there
Retaining stock interior..pics would be greatly appreciated
Old 10-24-2021, 08:13 PM
Dave M's Avatar
Dave M Dave M is offline
Following. I might need one too
Old 10-24-2021, 10:47 PM
LT4USMC LT4USMC is offline
After and before
Sent from my SM-G988U1 using Tapatalk
Old 10-24-2021, 11:17 PM
R 70 Judge's Avatar
Having a custom cage built will almost always be better than any pre-bent kit. If you are going fast enough to need a 8 point cage you may want to consider upgrading the seats from a safety standpoint.
James
1970 Trans Am
Old 10-25-2021, 08:36 AM
firechicken's Avatar
firechicken firechicken is offline
I used a prebent main hoop from Competition Engineering (I think) which fit really well after trimming for placement. The rest is custom fit. No pictures sorry.
Old 10-25-2021, 10:55 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I had bought a kit and the guys that built my cage for the Camaro said if it well and they made a few custom bars. They wanted interior in if I was going to use interior. Still a little tight on side bars and the door arm rest/handle. Had to clearance". They just forgot the D bars-but in their defense I said 10.0s was the goal
ID:	576092   Click image for larger version
ID:	576093   Click image for larger version
ID:	576094   Click image for larger version
ID:	576096   Click image for larger version
Skip Fix
Old 11-09-2021, 07:10 PM
David Holmberg's Avatar
Honestly, I didn't like the looks of the pre-made kits. My installer custom bent all the bars to fit the way I wanted them. More expensive, but better in the long run. Had I gone with a kit I would have regretted it every time I got in the car.
The Following User Says Thank You to David Holmberg For This Useful Post:
Old 11-09-2021, 09:22 PM
Curtis Slowe Curtis Slowe is offline
https://youtu.be/MJRFXTdblzs
My 10 point that I bought from Wild Rides in New Jersey. Couldn't be happier with it. Chromoly. I added a couple of gussets and door sill bars. Bought a window net from them that fit really nice as well.
Old 11-09-2021, 09:49 PM
ta man ta man is offline
That is my plan with mine..I have a great local guy...he basically asked is it a "nice car"and I said I want it to be a nice car after! That is why I came here!
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
The Following 2 Users Say Thank You to ta man For This Useful Post:
Old 11-10-2021, 07:55 PM
ponjohn's Avatar
ponjohn ponjohn is offline
The front down bars through the dash is the way to go.
Old 11-11-2021, 08:48 AM
BDHABT's Avatar
BDHABT BDHABT is offline
Ours down bars are welded to the dash bar,which sits behind the dash.
Alot of different ways to do it.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 11-15-2021, 04:00 PM
R 70 Judge's Avatar
James
1970 Trans Am
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 11-18-2021, 05:24 AM
Brian Baker's Avatar
S&W makes a decent pre-bent kit, and you can order the rear bars that pass through the rear shelf (instead of the rear seat back)...however, a custom bent setup would be best, and if I had to redo my old '79 T/A again, I would've went the custom router instead of the S&W kit.
