Old 11-11-2021, 12:23 AM
tom s tom s is offline
Default Upper radiator hose spring
Any issue using a spring in a upper hose?Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 11-11-2021, 08:49 AM
chrisp chrisp is offline
Yes watch your eyes when installing.
The Following User Says Thank You to chrisp For This Useful Post:
Old 11-11-2021, 09:22 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Why would you, though? It's positive pressure...
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following 2 Users Say Thank You to nUcLeArEnVoY For This Useful Post:
Old 11-11-2021, 11:55 AM
burd burd is offline
Put springs in the heater hoses too
The Following User Says Thank You to burd For This Useful Post:
Old 11-12-2021, 10:12 AM
78w72 78w72 is offline
X2. what would be the reason or benefit to putting springs in the upper or heater hoses? never had or heard of an issue with those hoses like how a bottom hose can collapse & needs a spring to prevent it.
Old 11-12-2021, 10:39 AM
No problem at all.
I for one don't like the look of a top hose that sucks flat after you park the car and the engine cools off.
If a hose doesn't fit 'just right', the sping will prevent a kink.
Clay
The Following 2 Users Say Thank You to "QUICK-SILVER" For This Useful Post:
Old 11-12-2021, 11:03 AM
Q-S,thats exactly what happens with one of my cars and not all the time!I ordered some stainless springs.Tom
Old 11-12-2021, 01:00 PM
My point is you don’t need springs in anything but the bottom hose. Upper hose expands when hot. Why would you put a spring in there.
Get the rite hose.
Old 11-12-2021, 02:03 PM
It IS the correct hose,no clue why it will collapse on just that car.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
Old 11-12-2021, 02:53 PM
wolf's Avatar
wolf wolf is offline
Check your rad cap if your cooling system is pulling a vacuum when it cools off.
The Following 2 Users Say Thank You to wolf For This Useful Post:
Old 11-12-2021, 03:55 PM
Default That's It
Hose is a wimp and/or radiator cap is too strong and not letting coolant get pulled back in when the engine cools off.
If the car doesn't have coolant recovery system. it's air contracting when the engine cools off. Raising cold coolant level would help with that. And the hose would still be wimpy.. Not as stiff/rigid as factory.
Clay
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post:
Old 11-13-2021, 10:12 PM
mgarblik mgarblik is offline
Just for the heck of it, try a radiator cap off one of your other cars. Possibly, something is going on with the gasket, vent or non-vent style, or something with the cap.
I can't see any prob;em using a spring if you want to. Other than it getting tangled up in the thermostat. I would leave it short and back from the housing several inches.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 11-14-2021, 09:01 AM
77 Canamman's Avatar
I had a 1984 Caprice with a 305. It would suck the upper hose flat if the RPM's went over 3000. Don't know why it did that. It would run warm if worked, but ran great right to 150k miles.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
The Following User Says Thank You to 77 Canamman For This Useful Post:
Old 11-14-2021, 10:04 AM
Here you go, put this metal hose kit on, it looks good at the shows, and makes you go faster.
Old 11-14-2021, 10:37 AM
Thats NOT going to happen!Tom
