Old 11-12-2021, 05:48 PM
1stgenbird's Avatar
1stgenbird 1stgenbird is offline
Default Engine Builder
If you were going to choose a company to either build your engine or purchase a custom build from, would you use Butler or Tin Indian? They both seem to build excellent Pontiac engines.
Old 11-12-2021, 06:50 PM
ID67goat's Avatar
ID67goat ID67goat is offline
My vote would be for a reputable local area builder...
The Following User Says Thank You to ID67goat For This Useful Post:
Old 11-12-2021, 06:59 PM
pastry_chef's Avatar
Looks like Len Caverly is within one hour of the OP. I'm not sure if Len still does engine builds.
Old 11-12-2021, 11:15 PM
Chris65LeMans's Avatar
Kauffman. Butler was too busy to even talk to me on the phone when I was calling around for quotes.
Old 11-13-2021, 09:23 AM
1stgenbird's Avatar
Thanks for the replies.
I just was putting the question out there at this point. I have my eye on a '69 428 and if I do move forward on it, then I will do more research. Butler and Kauffman are the two most prominent Pontiac builders and I know a couple of local guys that have Butler built engines that like them.
There is a shop not too far from me that has a good reputation but doesn't specialize in Pontiac builds. I would speak with him first.
Old 11-13-2021, 09:32 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
do your own research!!!...then have an intelligent discussion with your local guy. This is NOT surgery nor is it Astro-physics....in fact there aren't too many things actually "NEW" to building a motor. With all that said...there are secret little things that PONCHOS NEED vs ...XXXX. A good mechanic (and probably machinist) and in-depth research will yield you a nice reliable project.
The Following User Says Thank You to 67Fbird For This Useful Post:
Old 11-13-2021, 09:38 AM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
https://www.facebook.com/paul.spotts.7
Old 11-13-2021, 10:07 AM
TAKerry TAKerry is offline
Agreed. I interviewed a couple of guys before I found someone to build my motor. When I found the guy that does my work I asked if he had ever built a Pontiac motor. He started laughing and said he had 'blown up more Pontiac stuff than I had ever seen'. Kinda tongue in cheek but the story was he started pulling pontiac motors out of junk yards when he was a teen to build motors for his race car. He is a very successful drag racer, and def knows how to build a motor. Big name guys are ok, but I would not go that route just for bragging rights. My money comes too hard.
The Following User Says Thank You to TAKerry For This Useful Post:
Old 11-13-2021, 10:39 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
X2 find a local Pontiac guy
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 11-13-2021, 11:15 AM
gassman_67's Avatar
gassman_67 gassman_67 is offline
Default engine
Don't rule out Kauffman
https://www.facebook.com/KauffmanRac...6873234225938/
KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9".
552HP 594 TQ
