Old 01-20-2022, 12:37 PM
67post3spd's Avatar
67post3spd 67post3spd is offline
Default adjustable rear upper control arms. which year do i need?
I put a 71 buick 8.5 in my 67 gto a few years back. Need to correct my pinion angle ,and wondered if it mattered if I used the early arms {longer } or the later arms {shorter}.
I would think the longer arm shortened would be better as long as there is enough adjustment. haven't decided a brand at this point. Experiences or opinions?
thanks
Tim
Old 01-20-2022, 01:28 PM
Mike Davis's Avatar
You will need the 64-67 arms. The ears on the housing are in the same place, you need the control arms for the chassis used.
I would look at either BMR or UMI.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 01-20-2022, 04:19 PM
67post3spd's Avatar
thats exaxctly what I wasnt sure about, since the old rear is long gone. thanks
Old 01-20-2022, 04:27 PM
ZeGermanHam's Avatar
And to add to Mike's comment, if you get UMI (which I recommend), get their "roto-joint" style bushings to reduce binding. Don't use regular polyurethane bushings in this location.
https://www.umiperformance.com/home/...s-roto-joints/
1998 BMW 328is (track rat)
Old 01-26-2022, 04:12 PM
389 389 is offline
I like the Spohn Del Spheres with two rubber bushings in the rear end.
