Old 01-23-2022, 05:02 PM
slowbird's Avatar
slowbird slowbird is offline
Default What will it make?
Time to play what will it make (im putting the thread in street section because it will see quite a bit of street use)
4.250 stroke 4.380 bore
11:1 pump gas
Wide port e-heads ported by Butler touched up by SD flow [email protected] 2.250in 1.74ex (bought used).
Used ported Victor (somewhat matches heads)
1150 carb setup for pump gas
269-276 .750 112l/s cam
2 1/8 headers.
Hope to have it on dyno soon'ish
Old 01-23-2022, 06:22 PM
AG's Avatar
AG AG is offline
750 Hp with similar torque numbers at least.
Old 01-23-2022, 06:36 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Hmmm. Seems most to all would have missed on that 350 the other day.
Old 01-23-2022, 06:44 PM
Gary H's Avatar
Gary H Gary H is offline
I venture a guess of 789 HP and 725 torque
Old 01-23-2022, 08:11 PM
4dblnkldude's Avatar
I'll go 738 HP and 760 torque.
Old 01-23-2022, 09:44 PM
PAUL K's Avatar
PAUL K PAUL K is offline
865 if I fix the heads
Go fast, see Elvis!
Old 01-23-2022, 11:07 PM
slowbird's Avatar
If? You need to get on it, time is running out.
Old 01-24-2022, 04:07 AM
chuckies76ta's Avatar
512 cubic engine. 810 hp 750 torque.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 01-24-2022, 08:54 AM
PAUL K's Avatar
Five years later and now all of the sudden you are in a hurry. Funny!
I'll have them done before you can get pushrods!
Go fast, see Elvis!
Old 01-24-2022, 09:03 AM
slowbird's Avatar
Correct because i need the heads to measure for pushrods length
The Following User Says Thank You to slowbird For This Useful Post:
Old 01-24-2022, 02:50 PM
What size or Diameter push rod are you going with? Thanks
950 Quickfuel.
Old 01-24-2022, 03:36 PM
slowbird's Avatar
Biggest that'll fit. Won't know until we get everything bolted together. But absolute minimum will be 3/8 thick wall which due to supply chain issues are really hard to get right now.
904 HP @ 6500 rpm
Old 01-24-2022, 06:00 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
810 hp
Old 01-24-2022, 06:19 PM
Mike Davis's Avatar
855 with a small splash of Q16.....lol
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 01-24-2022, 06:22 PM
steve25 steve25 is offline
What do you mean by saying that the intake somewhat matches the heads?
I could deal with the interface at the flange being somewhat smaller since that is a straight run and it does not even take the area of a wide port to flow 370 cfm, but you for sure need a good amount of added port area from the point in the manifold where the runners turn hard and from that point on up to the intersect of the runner and plenum.
I going to go with a what I think is a generous 770 hp , especially in light of only having 11 to 1 compression.
Old 01-24-2022, 09:45 PM
PAUL K's Avatar
There is power to be had by deliberately mismatching the intake runners at the gasket flange on certain combinations.
Go fast, see Elvis!
Old 01-24-2022, 10:06 PM
Jack P. Jack P. is offline
Are you talking about having the bottom of the intake port a bit higher than the start of the heads so the air/fuel has a little ramp to jump off of.
Old 01-24-2022, 10:26 PM
PAUL K's Avatar
No Sir
Go fast, see Elvis!
Old 01-24-2022, 10:28 PM
No Sir
I have heard that works too.
