EFI Tech All things EFI and making classics modern!
Old 04-01-2022, 10:43 AM
DogMeister's Avatar
DogMeister DogMeister is offline
Default Holley Sniper Quadrajet EFI
This is the 461 build I did in 2013 which is now in my '67 GTO restomod project. It has been converted to the Holley Sniper Quadrajet EFI. The installation is complete, and I installed the Holley in-tank fuel pump which eliminates the need for a return line. Added Vintage Air also. Next task is to hookup the master cylinder and bleed the system. Hoping to fire it up within the next week or so.
461 Stroker Built by Me -
Old 04-01-2022, 11:04 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Nice! Let us know how it works out. I have an '86 K5 Blazer that I want to put this on.
Old 04-01-2022, 11:12 AM
Scott65's Avatar
Scott65 Scott65 is offline
That's a nice looking engine compartment! Good luck with the fire up
'65 Tempest 467 3650# [email protected]
Old 04-01-2022, 01:10 PM
LKLusza's Avatar
LKLusza LKLusza is offline
Dogmeister - what a sweet looking install! Since you used the same setup as I did, you might want to check out the post I just put up regarding dead head fuel systems and EFI. it's at: https://forums.maxperformanceinc.com...73#post6331373
Good luck with your setup You won't be disappointed.
Larry
Old 04-01-2022, 02:35 PM
67Fbird's Avatar
67Fbird 67Fbird is offline
NOT trolling.... What Tranny? I have an OLD 950 mutilport system and had to scratch make a TB lever to accommodate the TH2004r tranny TV cable.... (circa 2007) I would assume that HOLLEY fixed this f*cking PITA? as secondary opening leverage ratio was only about .100" OFF... or offer a lever with stud to be used?
Old 04-01-2022, 03:03 PM
DogMeister's Avatar
Interesting. I'll have to ask my buddy who put this system in his '78 TA. I do have a section of rubber hose, hope that will be enough. You'd think this would be something Holley would have anticipated. I guess we'll see what happens.
Old 04-01-2022, 03:05 PM
DogMeister's Avatar
I'm running a TKO-600 5-speed.
