Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 05-18-2022, 09:01 AM
mysticmissle's Avatar
Default NEW IA2A ready to assemble
sold car this was designated for, will consider selling short block and a set of heads.
virgin block fresh from machine shop jail, 55mm roller bearings, bushed 903 lifter bores, dry deck
4.31 bore ross pistons, 6.75cc dome, 2.35/1.9 valve reliefs, BWE rings already hung on the pistons which are on GRP aluminum rods
Scat 4.35 stroke crank with SBC rods journals, crank is 10/10. 1967 bob weight balanced to 1/3 of a gram, FM main and rod bearings included
comp cams 55 mm roller cam
270/286 112 lsa .521/.500 lobe
Crower 903 offset, bushed lifters
contact me if serious
19k will add pics and head details
Old 05-21-2022, 08:36 AM
ErikW's Avatar
ErikW ErikW is offline
"A" for aluminum?
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 05-21-2022, 08:40 AM
Yes a for aluminum and expensive lol pics coming
Old 05-21-2022, 08:42 AM
Default Pics1
Pics
ID:	591232   Click image for larger version
ID:	591233   Click image for larger version
ID:	591234   Click image for larger version
ID:	591235   Click image for larger version
Old 05-21-2022, 08:44 AM
Default Pics2
Pics2
ID:	591237   Click image for larger version
ID:	591238   Click image for larger version
ID:	591239   Click image for larger version
ID:	591240   Click image for larger version
Old 05-21-2022, 08:45 AM
Pics3
ID:	591242   Click image for larger version
ID:	591243   Click image for larger version
ID:	591244   Click image for larger version
ID:	591245   Click image for larger version
Old 05-21-2022, 08:47 AM
Pics4
ID:	591247   Click image for larger version
ID:	591248   Click image for larger version
ID:	591249   Click image for larger version
ID:	591250   Click image for larger version
Old 05-21-2022, 08:50 AM
Pretty much everything needed for short block, is included. Only thing I can think of that I need to order if o keep it is rear seal of your choice and head gaskets
I have a set of hiports at the shop being looked over and a set of tigers fresh from the shop. If you buy the short block you will have first choice of cylinder heads and I will keep the others.
Hiports shouldn’t be too long before done. When they are I will make a decision on which motor is going in my gto and this aluminum motor may no longer be available
Old 06-06-2022, 05:55 PM
$18,500 consider trades towards a convertible pontiac or buick
Old 06-30-2022, 02:44 PM
A for Available
Old 07-22-2022, 06:05 PM
buy this and my tigers and have your fast and junk ready for norwalk
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 09-23-2022, 08:20 AM
last price drop before it starts going together $17000 tigers/kre heads are no longer available in the package
Old 09-23-2022, 01:21 PM
drool...putting on xmas list
Old 09-24-2022, 05:36 PM
nmoreilly nmoreilly is offline
Just curious, what compression ratio were you targeting in this motor ?
Old 09-24-2022, 06:50 PM
All depends on head Cc head gasket thickness and diameter
But we are planning on 14+ W 65cc heads
Old 09-25-2022, 07:18 PM
Thanks, currently have an iron IAII with hi ports in my 66 GTO but want to go all Aluminum. This is very cool but probably too much for what I’m trying to do in a predominantly street driven car
https://youtu.be/vz-l29omL70
The Following User Says Thank You to nmoreilly For This Useful Post:
Old 10-16-2022, 09:10 PM
Bump
Old 11-30-2022, 11:34 AM
Available for Santa
Old 01-18-2023, 06:19 AM
Currently available
Old 02-28-2023, 04:51 PM
most likely last bump, before i start assembling, will consider (car) trades up or down money wise, in next 3-4 weeks
