Old 07-02-2022, 05:31 PM
joes455 joes455 is offline
Default Alternator pully
Anyone know where i can obtain a 3" or 3 1/2" pulley.Stock pulley is 2 1/2" and takes too much belt tension to prevent sqeeling using the duralast 1352-6-3 105 amp inwhich destroyed front alt bearing.It has a lifetime warranty but i hate to tear another one up .yes serpentine whould be the way to go.
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
The Following User Says Thank You to joes455 For This Useful Post:
Old 07-02-2022, 06:33 PM
stellar stellar is offline
what width size is your belt?
Old 07-02-2022, 07:29 PM
tom s tom s is offline
I bought a deep alt pulley on ebay!Never lost a belt.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 07-02-2022, 10:23 PM
That style alternator had rear bearing problems. It was usually the rear that would get destroyed. Probably a defect bearing. You have a warranty. Why not try again. A bigger diameter pulley would lower the output curve.
The Following 2 Users Say Thank You to stellar For This Useful Post:
Old 07-02-2022, 10:36 PM
3 inch Delco pulley. Number 8 size. very uncommon size. Corvette used wider pulleys than this and they also had a deep groove meaning wider belt capability. A Vet pulley may be what Tom got on ebay.
The Following User Says Thank You to stellar For This Useful Post:
Old 07-02-2022, 10:39 PM
Schurkey Schurkey is offline
It comes with a serpentine, 6-rib pulley.
https://www.autozone.com/batteries-s...6-3/540688_0_0
What pulley did you install? Is it the right one for the belt width you have?
The Following User Says Thank You to Schurkey For This Useful Post:
Old 07-02-2022, 10:56 PM
AG's Avatar
AG AG is offline
Summit has plenty.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 07-03-2022, 06:18 AM
25stevem's Avatar
25stevem 25stevem is offline
I would like to questioning if you don’t mind why you need such a high amperage Alt in the first place?
At idle are you running A/C, Rad fans, high beams on and a cranked out 1100 watt stereo?
I do stuff for reasons.
The Following 2 Users Say Thank You to 25stevem For This Useful Post:
Old 07-03-2022, 08:16 AM
Running stock size v belt for alternator,replaced serpentine pulley with stock v pulley.Old style 10si couldn't keep up with elec trans cooler fan,in tank fuel pump,blower motor ,wipers volts would drop to 12.5 at cruise at idle 11.5 -12.Will check summit
Old 07-03-2022, 08:55 AM
Half-Inch Stud's Avatar
cogged vee belt for PS, but smooth or cogged Gates (if you can find it) for Alt. Definitely helps to find that larger Pulley. I got all mine from the u-pull-its.
Old 07-03-2022, 11:00 AM
Just ordered march performance -150 pulley 4" from scummit.thanks everyone
Old 07-03-2022, 12:25 PM
george kujanski's Avatar
A larger diameter pulley will lower your output at any speed, so if your output is not at 14 volts now at cruise and idle with the loads you have it definitely will not be better with a larger diameter pulley. With any alternator, current output INCREASES with alternator shaft speed to a limit at about 6000 RPM shaft speed. Increasing pulley size reduces your shaft speed at a given engine RPM.
George
The Following 3 Users Say Thank You to george kujanski For This Useful Post:
Old 07-03-2022, 01:30 PM
The Voltage Regulator will provide!
Old 07-03-2022, 03:33 PM
George voltage drop was with the stock 10si .I now have a cs style alternator
Old 07-07-2022, 10:19 AM
HWYSTR455's Avatar
CS130s are known to bearing failures, the bearings are too small.
A 4" pulley will definitely lower your output, especially at idle, and you will be right back to where you started.
I would suggest a 12si type, my go-tos are the PowerMaster 7294 & the 47293 (100a/150a respectively).
The Following 2 Users Say Thank You to HWYSTR455 For This Useful Post:
Old 07-07-2022, 11:24 AM
Formulabruce's Avatar
12Si is a great choice, but a 10si can easily be built to handle the load if the battery sized and up to the tasks.
The Following User Says Thank You to Formulabruce For This Useful Post:
