Tri-Power Tech 57-66 Tri-Power Talk
Old 07-20-2022, 01:32 PM
Pontiac62's Avatar
Pontiac62 Pontiac62 is offline
Default Phenolic Spacers
My car is a 62 GP with tri-power. I'm planning to put phenolic spacers under the carbs for heat isolation. Will that also require different tubes from the manifold to the choke?
What thickness spacers should I use, and who sells them?
Thanks, Les
Old 07-20-2022, 01:54 PM
tom s tom s is offline
I might have a set I no longer need.Tom
Old 07-20-2022, 01:57 PM
I do,center is for a 61-65 intake and has a fitting for a PCV.Tom
Old 07-20-2022, 01:59 PM
Like these.Tom
https://www.ebay.com/itm/37405929968...MAAOSwKoNic8lH
Old 07-20-2022, 03:17 PM
pfilean's Avatar
pfilean pfilean is offline
Pontiac TriPower website listings for choke tubes 61-63 imply that different choke tubes may be needed for applications with the PCV spacers than for applications without PCV spacers.
As I remember when I added the PCV spacers on a 61 manifold I used the choke tubes I had with no problem. However, those tubes were probably from a 64 which is a slightly higher rise manifold and may have need the longer choke tubes.
Old 07-20-2022, 04:33 PM
Pontiac62's Avatar
I notice that spacers appear to be available in 1/2" and 1/4". Any advantage to either?
thanks, Les
Old 07-21-2022, 08:29 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
thanks, Les
Go to Pontiactripower.com , or call John Wright @ 847 767 2868. He has what you need.
Old 07-21-2022, 07:54 PM
Dick Boneske's Avatar
I have quite a few spacers, gaskets, and the choke tubes to work with raised carbs. I do have a few OEM spacers from the early sixties' cars.
PM me with your needs.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-21-2022, 08:59 PM
lucky1 lucky1 is offline
Default Heat insulators.
Check out Hotrodcarbs.com.
Old 07-28-2022, 05:09 PM
Pontiac62's Avatar
Thanks everyone for your help.
Les
