Old 08-18-2022, 08:23 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default brake adjuster
with the brake tool starting at the bottom of the oval opening and spinning the adjuster UP, does that tighten or loosen the rear brakes . Hard to spin the tires with posi rear.
Thanks, Dave
Old 08-18-2022, 11:06 AM
ponchonlefty ponchonlefty is offline
Thanks, Dave
it should loosen.remember the self adjuster is designed to push down to tighten the brake.
Old 08-18-2022, 11:26 AM
Murf Murf is offline
I think up at the back will tighten. The hole your talking about is on the backing plate, right?
Murf
Old 08-18-2022, 03:02 PM
Not sure if Chevy is the same, but I just went through this on my 55. The manual says to turn the adjuster wheel toward center of wheel. That would mean up.
Old 08-18-2022, 05:15 PM
67drake's Avatar
67drake 67drake is offline
Rotating the back side of the star wheel up tightens the brakes.
‘55 Catalina
Old 08-22-2022, 11:00 AM
dhcarguy's Avatar
Thanks EV1, I did figure it out. I took the wheel and drum off. From the back of the adjusting hole, I turned the star wheel UP to tighten.
