Old 10-12-2022, 08:25 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default Iskenderian valve springs
Pick these up at a swap meet for $20. Anyone have an idea of age. They are new never been used
ID:	600328   Click image for larger version
ID:	600329   Click image for larger version
Old 10-12-2022, 09:00 PM
25stevem's Avatar
25stevem 25stevem is offline
If there new then what does there ago matter?
Also if those are Aluminum retainers they should go in the garbage!
I do stuff for reasons.
Old 10-12-2022, 09:56 PM
242177P's Avatar
242177P 242177P is offline
I'm curious about this as well. Early roller cam stuff, or ancient boxes that just stuck around?
Old 10-12-2022, 11:33 PM
NeighborsComplaint's Avatar
I might be being too logical here, but since they are Isky springs and you have a Part# on the box, you could call Isky Cams and ask if they have a record of the old part#. They might be able to provide the specs.
No guarantee the springs match the box unless the Part# is stamped into the spring. I would just have someone check the pressures at a given installed height and max lift to be sure. Diameter (for application) can be cross referenced to currently available springs.
Triple Black 1971 GTO
Old 10-12-2022, 11:45 PM
Who knows, if you call for technical support Ed Iskenderian himself could be the one taking your call. He’s still there running his business at 101 years of age.
Just how cool would that be?
https://www.iskycams.com/shop/
Old 10-13-2022, 06:09 AM
Steve C. Steve C. is offline
In my 2004/2005 ISKY catalog those inner/outer color codes do not correlate with any spring listed.
However they can be found here on page 16 :
https://iskycams.com/userfiles/files...pec%20Book.pdf
Rated at 1.650" with 115 lbs seat pressure.... not a roller cam spring for a Pontiac valvetrain mass (pushrods, rockers, valves and springs) in my opinion !
Old information here:
Old 10-13-2022, 07:26 AM
A fwiw.... for conversation around the coffee table. In the 2004/2005 ISKY catalog the recommended valve spring for all their Pontiac solid roller cams was the number 9265, and with this notation... "For use on later model ram air IV or late production aftermarket alum cylinder heads (1.875") installed height required".
That spring is listed here on page 6
Note the pressure involved.
Old 10-13-2022, 11:26 AM
P@blo's Avatar
P@blo P@blo is offline
1005-W and 206-G are on page 16 column 1 of the book Steve posted the link for.
Old 10-13-2022, 01:02 PM
hobbygto65's Avatar
Probably not going to try and use these, bought mostly for shelf art. I was just curious to see if anyone new what year they were. Specifically the box. The springs are correct for the box.
Old 10-14-2022, 11:03 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
I should fix up Ed Iskenderian with my great Aunt thats 105.5 years old. Nevermind, he'd probably get her "in trouble" and they'd have to get married.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400 pontiac
72 4-4-2 Mondello's VO Twister II
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
Old 10-14-2022, 12:09 PM
25stevem's Avatar
When Ed does pass I wonder if the person at the mortuary will be able to get the cigar out of his mouth so the coffin can eventually be closed?
