drove 66 for first time today after putting together. turn signals don't self cancel should they? didn't have a steering wheel on it when i got it so don't know if some parts are missing?
The turn signal lever will self-cancel if installed correctly and not broken.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
They should cancel, possibly the cancel cam was left out, usually they cancel on at least one side if cam is still there.
Google 66 GTO turn signal cancel cam and you should be able to see if you left it out.
64 Lemans hardtop 4spd, buckets |
As mentioned yes the Turn Signals should cancel (Turn off) when the turn is completed.
You may luck out and find that the Cancelling Cam was not installed or the more common issue of broken ears on the Cancelling Actuator on the turn signal switch itself. The good news (Sort Of) is they make a repair piece for the latter.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
Not that its the case here, but with a fast steering box and a (too) small aftermarket steering wheel my 66 won't cancel (even with a new switch signal).
1966 Lemans convertible 455/5spd 1968 Firebird convertible 400/4spd Need more Pontiacs! |
I don't know how either of those things would have an impact on the cancel cam in the steering column.
