Old 12-17-2022, 03:26 PM
1965gp 1965gp is offline
Default 14” Rally II’s rear will clear disc brakes?
I want to put Rallye II’s on my 69 GTO. It’s a factory disc brake car and has 14” steel wheels that clear the caliper. Since I already bought the original style 14” white line tires I would like to keep them as 14”. Are there special 14” Rallye II’s that clear the caliper or do they all clear the caliper?
I would think that the G body Grand Prix Rallye II’s would work?
Old 12-17-2022, 03:43 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
I think any wheel that came on a car with disk brakes will work.
After 1969 I belive they will all work.
Old 12-17-2022, 03:56 PM
I will have to try a few and see if they work. I have some but no idea where they came from
Old 12-18-2022, 02:48 PM
imposter's Avatar
imposter imposter is offline
they for sure work ive used them with stock setups and will clear wildwood setup with 1/4" wheel spacer
Old 12-20-2022, 01:16 PM
squidtone's Avatar
squidtone squidtone is offline
I'm under the impression Pontiac went with the single piston calipers in '69, so most any 14" Rally II should fit.
(Cars from the previous two years with disc brakes used 4 piston calipers and code JA or JC Rally II 14 x 6 are required to fit those [and I think some even more rare codes might work too])
A main difference between the JA, JC code wheels and all later 14" Rally II wheels is the 5 depressions for the lug holes are almost a 1/4" deeper to create a wider "stand-off" to clear wide (pistons both sides) calipers.
Single piston calipers are "svelte" by comparison.
Dave
http://www.squidsfabshop.com/?
(updated January, 2013, Pypes exhaust installation)
Old 12-27-2022, 09:35 AM
Maxthe222 Maxthe222 is offline
On that note, is there any truth to the rumour that you couldn't get the rear disc brakes on the 1979-81 Firebirds without having 15x8 wheels? I heard that all WS6/J65 cars came with 15" space savers as the 14" ones could clear the disc brakes.
Old 12-27-2022, 11:33 AM
Didn’t they sell WS6 cars with Rallye II’s?
Old 12-27-2022, 12:40 PM
No, when WS6 pkg was introduced for '78 models, 15x8 snowflake wheels & 225-70R15's were part of the package. The only OEM install of smaller size wheels with that factory rear disc setup, were the 15x7.5 turbo wheels which became avail on 81 models in natural(silver) & in white (NASCAR Pacecars).
It's possible to mate the OEM '79-81 rear disc setup with 14x7 rallyII's though some mild grinding which has to be done to an area on the original calipers. Been over 25 years since I setup such a swap, was performed on a 8.5 X-body (c-clip axle) rear that I setup with 3.42's & a posi. Went in a '69 Bird.
Old 12-27-2022, 03:50 PM
We have one set of these left. They fit 14" rims with no grinding but require custom parking cables.
https://scarebird.com/index.php?rout...product_id=146
