I have a reproduction R59 battery in my 1969 GTO from Antique Auto battery that is going to need a replacement.. This is my second one in 15 years so I did well with them I think regarding the lifespan though the first lasted longer than the second.
Since I have the battery already is there anyone out there that can remove the old internals and install a new battery in the case? or, does anyone make a R59 case that would hold a new battery? I did the battery topper years ago and don't want another. I see Antique Auto Battery is under new ownership and the reviews are not good at all and there is a 90 to 120 day lead time for a new one.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming. 67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project. |
Looks like Turbo Start has an AGM version of them. That should last even longer. https://turbostart.com/product/sr59/
"I know just enough to keep me here, but not enough to get me out" |
I ordered one from Battery Central Mall and received it 17 weeks later this past November. The R59 reproduction is from Antique Auto Battery. I haven't installed it yet. Fully charged open circuit voltage was 12.98V, typical for an AGM type. Cranking Amps measured with an AutoX-ray Battery tester showed 625 cranking amps. They recommend the Bulk Charging current to be no more than 10-12 amps so I bought their recommended charger, a Soneil 1220SR 20CC. I understand that the AGM battery inside the reproduction case is an Odyssey ODS-AGM28L (PC925).
I did nor order the Turbo Start version because the positive terminal is the same size as the negative and the (+) spring ring battery cable won't work with that diameter. Raised letters on factory installed Delco battery cases were unpainted, only the caps. Service replacements in the 60's and early '70s did have them painted. Testor Model Master paint 1705 Insignia Red should be close. From what I can tell, warranty stickers from 1970 & up were applied to service replacement batteries. Does anyone know if the service replacement batteries had them in 1966 to 1969? |
| The Following User Says Thank You to gto4ben For This Useful Post: | ||
Thank you both, very helpful.
While the Turbo Start sounds like a stronger battery I too have the spring ring cables so the terminal size would be an issue.
| The Following User Says Thank You to Mark Simiele For This Useful Post: | ||
Update: I installed the battery from BatteryCentralMall. It started my stock 67 GTO. Garage temp was 65F. Voltages below measured at battery terminals.
Fully charged open circuit voltage - 12.9V Courtesy lamp & clock load - 12.3V Cranking voltage for cold start (min) -8.8V Initial charging voltage -14.7V Everything looks good. |
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! Last edited by turbo69bird; 01-14-2023 at 12:11 AM. |
| The Following User Says Thank You to turbo69bird For This Useful Post: | ||
Just in case anybody gets stuck with an undersized post, they make repair shims. Never used them, just aware of them. HTH.
| The Following 3 Users Say Thank You to 242177P For This Useful Post: | ||
Thanks, I learn something new on here all the time… |
| The Following User Says Thank You to bluejudge For This Useful Post: | ||
I received my battery a few days ago and I also was discouraged by the + battery post. Here's how I made the fix. I took a aluminum ski pole inside diameter of 11/16"and cut a 9/16" piece off and de-burred the inside edges. Next I prepped the post by using battery post tool and emery cloth. Next I used soldering paste and coated the aluminum sleeve and battery post. I then placed the sleeve on the post and used my soldering iron to lay a small amount of silver solder on the top. I then used my Bernzomatic torch and heated the top slowly till the solder sucked down inside the sleeve. I immediately poured cool water over to cool it quickly. I then removed the sleeve and it looks perfect. Installed it in my GTO and fired it up.
