Old 01-30-2023, 02:30 PM
rt400 rt400 is offline
Default OIL PAN HTTING
Hope someone has an answer. Put a 461 stroker in 68 GTO. Block is a 69 and has a stock Butler oil pan on it. Drivers side has plenty of clearance, Passenger side of oil pan seems to be hitting the bolt on the cradle that retains the brake line. Everything else lined up fine. Photos of each side of engine mount and difference in clearance. My original pan had the drain in the front, where this one is on the side. I wouldn't think that would be the issue.
ID:	606354   Click image for larger version
Old 01-30-2023, 03:38 PM
tom s tom s is offline
Very common with aftermarket pans.I know how to raise on first gens but not sure on A bodies.Maybe new mount would do it.Tom
Old 01-30-2023, 04:23 PM
OG68 OG68 is offline
Put in a shim between the frame mount and frame and reverse the mounting bolt so the head is on top.
Old 01-30-2023, 04:34 PM
Thanks Tom
I was thinking about changing mounts. I found they make shims also to go under the frame brackets.
Old 01-30-2023, 04:35 PM
Thanks OG68
Old 01-30-2023, 05:53 PM
mrgto69's Avatar
mrgto69 mrgto69 is offline
Pypes Staff - Tech
Default Frame spacers
Originally Posted by rt400 View Post
Thanks OG68
Hi Tom. I heard from a friend you are looking for my spacers... I still have and sell them.. $45 including shipping. PM me and we can talk. Thanks... Mike
Old 01-30-2023, 10:05 PM
Mike's spacers are nice
Old 01-31-2023, 12:09 AM
mrgto69's Avatar
Pypes Staff - Tech
Thank you.
Old 01-31-2023, 10:43 AM
Gastiresandoil's Avatar
Need a spacer on that passenger side definitely. The motor mount is resting on the frame, let alone the oil pan hitting anything.
Old 02-07-2023, 07:09 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
This problem always occurs when a Butler pan is used with
the stock mounts. the front of the Butler pan sticks down too much.
Old 02-08-2023, 09:08 AM
