Old 02-13-2023, 01:58 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Default Gas tank insulation
I'm putting in a tanks inc fuel injection tank. What is recommended to go on top of the tank between tank/floor board?
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 02-13-2023, 03:30 PM
grivera's Avatar
grivera grivera is offline
I used rubber strips between tank and trunk floor as well as between the straps and tank.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 02-13-2023, 03:56 PM
SRR's Avatar
SRR SRR is offline
Default Gas tank
I glued these rubber strips to the tank.
― Calvin Coolidge
The Following 2 Users Say Thank You to SRR For This Useful Post:
Old 02-13-2023, 04:06 PM
mysticmissle's Avatar
pretty nice kit with straps and hardware, tank pad and the rubber strips on ebay for about $90 i think toms classic parts or something i just installed it. Not exactly the same material for the pad but nice and thick and worked fine
Old 02-14-2023, 09:11 AM
Don 79 TA Don 79 TA is offline
i did that too
i think i also put zip ties on them to keep them on during the install, then snipped them off
my last setup i used some of my hydroturf matting from my jetski
we use it in them, so also worked out for what i needed
Old 02-14-2023, 04:02 PM
70GS455 70GS455 is offline
Patton Glade makes a reproduction of the original tank pad:
https://www.v8buick.com/index.php?th...nk-pad.136275/
Sent from my SM-T817V using Tapatalk
Old 02-15-2023, 01:10 AM
Carl S Carl S is offline
Roofing tarpaper is virtually identical to the original stuff that GM used.
The Following User Says Thank You to Carl S For This Useful Post:
Old 02-17-2023, 09:20 AM
didnt know that
that might be another easy option
i know my 79 originally had rubber type, but it was deteriorated
Old 02-18-2023, 08:12 AM
HWYSTR455's Avatar
I used a sheet of DynaMat on the top of my tanks. And yes, it does manage any tin-can drone.
You could use DynaLiner if you wanted to, but it won't manage any tin-can drone, only manage heat.
Technically, where one would want 'insulation' would be on the bottom of the tank, to manage radiant heat from the asphalt. But most don't want anything that's visible. Everything else is strictly for anti-squeak as the body flexes.
With EFI, there's less issues with the tank/gas itself of getting super heated, due to the psi.
