Old 02-15-2023, 06:07 PM
Gary H's Avatar
Gary H Gary H is offline
Default Hydraulic roller cam cores
Trying to get a Hydraulic roller camshaft ground and NOBODY has Pontiac cores available, and no ETA on any too. Anybody have any leads? I need one for a customer I'm building a 525' engine for. I need something in the 250ish intake and 260ish exhaust range. I can get solid roller cams but I'd rather go hydraulic if possible.
Old 02-15-2023, 06:28 PM
25stevem's Avatar
25stevem 25stevem is offline
How about buying a used solid roller of more lift and duration then you need and then getting it reground?
Have you tried Jones cam designs?
I do stuff for reasons.
Old 02-15-2023, 06:46 PM
tom s tom s is offline
Have you tried LSM?Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 02-15-2023, 07:00 PM
Formulajones's Avatar
May try giving Paul a call at Koerner Racing.
https://youtu.be/XqEydRRRwqE
The Following 2 Users Say Thank You to Formulajones For This Useful Post:
Old 02-15-2023, 07:32 PM
Steve C. Steve C. is offline
Give a call to Tim Goolsby directly at Bullet Racing Cams, ext 102.. He has repaired and re-ground many cams. If you find a core that needs repair it depends on damage, depth of hardness and profile. The price will be right.
Personally a few years ago I had Tim regrind a damaged solid roller cam for $157.50 + freight..
https://www.bulletcams.com/
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 02-15-2023, 09:33 PM
slowbird's Avatar
slowbird slowbird is offline
He's crazy expensive
Old 02-16-2023, 09:02 AM
64speed's Avatar
64speed 64speed is offline
Erson has them
Old 02-16-2023, 01:22 PM
racegto65's Avatar
racegto65 racegto65 is offline
I got the same answer yesterday trying to order a cam. I deal with George at Clay Smith and he told me he used to get cores by the pallet and now they are only coming 10 to 20 at a time.
Old 02-16-2023, 06:19 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Fairly recently LSM had some mid 250/260 .400 lobe cams ground and in stock. I don’t remember the exact specs.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 02-16-2023, 09:07 PM
Gary H's Avatar
I left them a message. I'll try again tomorrow.
Old 02-16-2023, 09:12 PM
Gary H's Avatar
Jones didn't have any. Also, when I spoke to Bullet they said they couldn't grind a hydraulic cam profile from a solid cam core used or otherwise.
I'm pretty sure I'm going to go with a solid roller cam instead. I spoke with multiple Pontiac racers at the Sick Week race today at Gainesville today and they all are running solid rollers. Driving them hundreds of miles too.
Old 02-16-2023, 09:21 PM
Dont give up on LSM,they did a RA V cam for me.tom
Old 02-17-2023, 07:16 AM
25stevem's Avatar
I would really love to know why Bullet said that gods used solid roller could not be re-ground into a hydro roller?
Did they give any explanation as to why that is?
Old 02-17-2023, 09:19 AM
Don 79 TA Don 79 TA is offline
what about a mild solid roller profile with the hyd lifters?
Old 02-17-2023, 09:42 AM
That doesn't give me a warm fuzzy feeling, lol. 100's of miles isn't much for a street car. I've noticed most of those guys running drag and drive events are also lashing valves twice a day to help them live. Basically tightening them up to near zero lash for the street drive, and then opening them back up for the race. That's not really conducive to what I'd consider a street car, nor would I want to go through all that trouble.
But hey, if guys want to go through that all the time, have at it. It's fun to watch but those guys really torture themselves to make those "race" cars survive.
Dad did the solid roller thing on the street, Tony spec'd something that was supposed to be soft on the valvetrain, and only needed 240lbs. on the seats, then used Crowers (very expensive) pin oiled rollers, and was a tight lash setup to start with. It lasted about 5000 miles on the street before a lifter went south. Not even remotely interested in solid rollers anymore for a street car.
Old 02-17-2023, 10:06 PM
Gary H's Avatar
OK, I got a hydraulic roller from Mark at Luhn Performance. He had one in stock that was pretty much the specs I was looking for. Also ordered his oil pump for the engine as well.
The Following 2 Users Say Thank You to Gary H For This Useful Post:
Old 02-17-2023, 10:36 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
We have several at https://pontiacspeedshop.com/camshaf...raulic-roller/
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
