Old 02-24-2023, 05:11 PM
gman005's Avatar
gman005 gman005 is offline
Default Bead sealer.
I can't find my old post of what bought in the past to glue my rear slicks. Any ideas?
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
Old 02-24-2023, 05:28 PM
Dragncar Dragncar is offline
If its drag radials Permatex # 1 is what you use. High Tack.
Old 02-26-2023, 09:20 AM
gman005's Avatar
80062 ?
71 Lemans Sport.
Old 02-26-2023, 09:34 AM
242177P's Avatar
242177P 242177P is offline
https://forums.maxperformanceinc.com...d.php?t=803335
Old 02-26-2023, 09:44 AM
Half-Inch Stud's Avatar
Don't ask me how i know that Belt Dressing spray is the wrong choice.
Old 02-26-2023, 10:27 AM
turbo69bird's Avatar
Yup this is what I used too. https://www.amazon.com/Permatex-8006...71699260&psc=1
But I also screwed mine (w the 4 speed naturally aspirated to the rims as well, that 60 ft was so important on that car.
My turbo car doesn’t hit the tires as hard so I haven’t run screws just the permeated and it’s been fine
960 HP @ 11 psi, 9.70 at 146.
Old 02-26-2023, 12:29 PM
gman005's Avatar
That's it 80019. Thanks for the help.
71 Lemans Sport.
Old 02-26-2023, 06:41 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Our shop uses this stuff from napa, its what i use on mine. No problems at 1.37 60 fts so far.
https://www.napaonline.com/en/search...aler/201805184
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 02-26-2023, 09:40 PM
Mike S's Avatar
Mike S Mike S is offline
I used the Permatex on my radials and had no problems,. Have been down to 1.29 60's hitting the tires with a trans brake, Never moved in 2 years. Just changed them this year and had no problem removing the tires that where glued. lacquer thinner cleans it right of the rims.
The Following User Says Thank You to Mike S For This Useful Post:
Old 02-27-2023, 10:30 AM
chuckies76ta's Avatar
Are you guy coating the rim all the way around on both sides with the product you use? Just the rim or the tire also? Curious.
Thanks.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 02-27-2023, 01:45 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
I have never put anything on the bead of my slicks in over 40years of racing. None of the big 3 that mount tires at the track do either.
The Following User Says Thank You to Ken MacNicol For This Useful Post:
Old 02-27-2023, 05:20 PM
I only coat the rim side of the bead, i dont run tubes. And the MT slicks are usually pretty rough in that area. So between dawn dishsoap on the inside and bead sealer trying to slow down any leaks at all and keep the slick from spinning.
6.27@107
9.97@131
Old 02-28-2023, 01:03 PM
Buy Hoosiers , they do not leak like the empties. No dish soap and no tubes needed.
