Old 02-27-2023, 09:33 PM
Default What is this truck guys?
Found this in warehouse clean out. nothing on back (doesn't mount on a belt). Thought air gauge . Just wondering with AUTOCAR on it. Pop always had Mack trucks.
ID:	608063   Click image for larger version
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 02-27-2023, 11:45 PM
242177P's Avatar
242177P 242177P is offline
"... maker of severe-duty trucks. In 1953, Autocar was taken over by the White Motor Company, which made Autocar their top-of-the-line brand."
"... was taken over in turn by Volvo Trucks in 1981 ..."
https://en.wikipedia.org//wiki/Autocar_Company
Not much help, but knowing which years (53-81) it might've been used could narrow things down a little??
Old 02-28-2023, 12:57 AM
Redpiston Redpiston is offline
Could be a belt holder for carrying around a truck tire air gauge. My WAG.
Old 02-28-2023, 03:39 AM
dataway's Avatar
dataway dataway is offline
Gauge for measuring a McGanzer Flange gasket.
Old 02-28-2023, 05:25 AM
242177P's Avatar
The original machine has a base-plate of prefabulated aluminite, surmounted by a malleable logarithmic casing in such a way that the two main spurving bearings were in a direct line with the pentametric fan. The latter consisted simply of six hydrocoptic marzlevanes, so fitted to the ambifacient lunar waneshaft that side fumbling was effectively prevented. The main winding was of the normal lotus-o-delta type placed in panendermic semi-bovoid slots in the stator, every seventh conductor being connected by a non-reversible tremie pipe to the differential girdlespring on the "up" end of the grammeters
The Following 2 Users Say Thank You to 242177P For This Useful Post:
Old 02-28-2023, 05:26 AM
dataway's Avatar
30 years of working on them and I'm still having issues with the Side Fumbling. Do you thinking it's the main windings or the semi-boviod slots?
Old 02-28-2023, 05:38 AM
242177P's Avatar
The Rockwell Retro Encabulator does everything Turbo Encabulator didn't.
The Following User Says Thank You to 242177P For This Useful Post:
Old 02-28-2023, 09:49 AM
burd burd is offline
AC thermometer holder
