Old 05-19-2023, 06:13 PM
poncho4554spd poncho4554spd is offline
Default Best place for 70-72 trans am decals?
If I am not mistaken, the most accurate set of decals for a 70-72 TA can be bought from Phoenix Graphics? Is that correct? Thanks
Old 05-19-2023, 07:22 PM
PY member (Greg S) went to a lot of trouble & had the correct decals made for the 70-72 T/A's.
After a period of initial sales, he turned the continued production & sales over to Stencils & Stripes in IL.
The Following 4 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 05-19-2023, 09:35 PM
Formulabruce's Avatar
This is correct, and many of us loaned Gregg Original NOS decals to have these made.
The quality was first rate, saw a set on Adrian at MACN.
" Long may we DRIVE !"
Old 05-19-2023, 10:13 PM
Ok. Thanks guys. I remember Gregg doing them. When I searched what I thought was his old web address, it went right to Phoenix so that's why I thought they were selling them. I will see if stencils and stripes has a y for a blue car.
Old 05-20-2023, 02:32 PM
72projectbird's Avatar
I have a set of his on my 71. They still look great after several years.
I remember PG messed up the stripes for blue cars. They were called out on it and it created a chit storm on TAC if I'm remembering correctly. Wasn't a good look for the site or PG.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 05-20-2023, 02:35 PM
Norwood's Avatar
Norwood Norwood is offline
I remember that well. I’m not saying I wouldn’t buy anything from PG but they would need to be my only option for me to do so.
Old 05-20-2023, 04:03 PM
necdb3's Avatar
necdb3 necdb3 is offline
You must be getting close on Glenn's car if you're looking for decals!!
Old 05-20-2023, 06:58 PM
R 70 Judge's Avatar
https://www.stencilsandstripes.com/p...s-am-firebird/
James
1970 Trans Am
Old 05-21-2023, 05:21 PM
Yeah, that watching that whole ordeal unfold definitely left a sour taste. It's too bad really. Oh well.
I reluctantly bought some decals for a 78 Corvette pace car from them, and it was awful. They're using a way to sticky transfer paper that makes it almost impossible to get thr decals off of.
1987 Grand National
Old 05-21-2023, 09:51 PM
Yes they will be for it. I am getting ready to start really moving on the car and want to get everything in order. I will post updates as I proceed
Old 05-21-2023, 09:54 PM
Thanks again guys.. Stencils and stripes it is. Hopefully they have a kit for a blue car or have one available soon if not.
Old 06-12-2023, 08:29 PM
hiyabradHO hiyabradHO is offline
They have been out of stock for a long time. He had not done another run. When you check for yours can you ask to see when the stripe set will be in for a white car?
Old 06-12-2023, 08:54 PM
To follow up on the OP’s question, I have seen a lot of places (Firebird Central, Classic Industries, etc.) selling “GM Officially Licensed” stripes. Has anyone seen those and can give an opinion on them?
Old 06-13-2023, 07:05 AM
Default 70-72 ta
I have a nos stripe set for a white car available
Old 06-16-2023, 06:47 PM
I received the blue stripe kit the other day from Stencils and Stripes. I forgot to ask about the white kits as far as when they will be available. Luckily I.needed one for a blue car which was in stock. Looking forward to getting these on after a little more assembly along with wet sanding and buffing
Old 07-24-2024, 01:35 PM
65madgoat's Avatar
Man you are lucky. I am out of luck it seems for a kit from Stencils & Stripes for a lucy blue T/A. No expected production date... damn
Old 07-24-2024, 03:20 PM
Norwood's Avatar
The last run he did we were able to get here on PY a commitment of I believe 20 kits.
The Following User Says Thank You to Norwood For This Useful Post:
Old 07-24-2024, 03:22 PM
Norwood's Avatar
https://forums.maxperformanceinc.com...ghlight=Stripe
Old 07-24-2024, 03:30 PM
Mr. G Mr. G is offline
I was able to order a set last November with no problem direct from S & S and just checked their website which showed the set for lucy blue cars to be available so you should be able to get them.
Old 07-24-2024, 04:06 PM
65madgoat's Avatar
Uhm, that is incorrect. They are NOT available. Only the hood stripe is for a Lucy Blue car.
Spoke with Ryan at Stencils and Stripes -- the last production run was in 2019. Production costs have doubled since then so he has not done more. He is checking to see if a 10 or 20 pre-order can get a run done - but cost will be higher by who knows how much. Maybe $600 a set or more. He is to get back to me.
WHO IS IN FOR A SET?
The Following User Says Thank You to 65madgoat For This Useful Post:
