Old 05-20-2023, 07:25 PM
caddor38 caddor38 is offline
Default Currie rear end slide on end caps
How are currie rear end housing slide on end caps removed and put on. I have a ford 9inch where one of the endcaps is messed up. Are these pressed in by a shop or welded.? Can this be done by a garage mechanic or driveline shop?
Old 05-21-2023, 10:36 AM
chiphead's Avatar
chiphead chiphead is offline
Got a picture? All the housing ends on a Ford 9" that I've seen were welded onto the axle tubes. The outer axle bearing fits into those ends, and then a bolt-on retainer holds the outer bearing and backing plate on.
A good driveline shop or rear end builder should be able to cut the weld, remove the end and then weld a new end on. Don't just cut it at the weld, the tube extends into the housing end. Verify they have a jig or a way to make sure the new housing end is clocked and spaced properly prior to welding.
Old 05-21-2023, 01:00 PM
Thanks, I included some pictures.
ID:	613005   Click image for larger version
ID:	613006   Click image for larger version
