Old 07-12-2023, 12:45 PM
Terry M. Hunt Terry M. Hunt is offline
Default Holes in firewall
The attached photo is of my 66 GTO convertible with A/C firewall. The holes numbered 1 2 and 3 appear to have been drilled by some previous owner, not stamped by the factory. They are near the large hole where the accelerator cable passes through the firewall. I need to confirm whether these holes are supposed to be there and what their purpose is or if I should close them up.
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 07-12-2023, 01:45 PM
6d7gto 6d7gto is offline
My '67 non A/C firewall has them. Not sure what they are used for but eventually will find out if and when I ever get this project put back together! Hopefully someone will know and chime in for you.
Old 07-12-2023, 04:31 PM
Cammer-6 Cammer-6 is offline
those holes indicated the screw is inserted from the inside.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-12-2023, 05:04 PM
The holes are deformed on the inside the way you would expect them to be if a sheet metal screw had been installed from the inside to attach something to the inside of the firewall, but what would that be?
Terry Hunt
Old 07-12-2023, 07:11 PM
Jeff Hamlin's Avatar
As we all know the 3 holes closest to the Cable hole are for the cable cup/shield.
Anything beyond that could be anything on a 50+ YO car.
I would just weld them up.
The Following 2 Users Say Thank You to Jeff Hamlin For This Useful Post:
Old 07-13-2023, 02:01 PM
ZeGermanHam's Avatar
My '66 with A/C has those holes, but some of them were covered with with a dab of seam sealer at the factory. First photo below is during teardown on my car, and the second photos is after media blasting. You can see where they dabbed the seam sealer.
I don't know what they were originally intended for, but they are factory and were not used in my car before restoration and I didn't use them for anything when putting the car back together.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 07-13-2023, 11:57 PM
Zegermanham, thanks so much for these photos. My firewall also had these blobs of seam sealer until I scraped them off. I thought they had been put there by the guy who media blasted the car! I have made a template of the holes so I can recreate them if I decide to. At this point, I’m planning to close them up before I paint the firewall.
How weird that they created these 3 holes for no apparent purpose, or no purpose that anybody is aware of.
Terry Hunt
Old 07-14-2023, 11:30 AM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Just my thoughts here. An old-style mechanical temperature gauge, the one with the hollow copper tube has a sensing "bulb" on the engine side. It's all connected as one piece to the back of the gauge. So that bulb needs a hole about as big as one of yours to get from the driver's side underneath the hood; and out to the intake crossover. Same with a real oil pressure gauge where hot oil is piped inside of the car directly into the back of the dash gauge.
A smaller hole than the temperature gauge needs, yes, but still an extra hole in the firewall.
Another one could very well be a mid-1960s era cable driven tachometer. (On a 1/4 mile car) They used to make a special distributor that had a take-off on the side where you thread on what looked just like a speedometer cable to drive the tach. One of those holes is big enough for that cable.
Peter Serio
Owner, Precision Pontiac
Old 07-14-2023, 02:23 PM
Pete big hole is for accelerator cable
others have confirmed they have the same holes,filled with seam sealer,
just like the OP,so I would say Fisher body did that.
I ll be getting my 67 out of storage soon so will have a look.
Firewall on it has never been molested.
Old 07-14-2023, 03:38 PM
Just curious so I took a look at mine. Seam sealer just like everyone else mentioned.
Sent from my moto g stylus (2021) using Tapatalk
Old 07-14-2023, 04:01 PM
gto4ben gto4ben is offline
Thanks for bringing this to our attention. Having engine fumes seep into the interior is anathema for me. On my 67 Lemans and 67 GTO Fremont assembled cars, #2 hole appears to be for the regulator mounting. I recall #1 and #3 were originally covered by black cemented cloth tape. You can see evidence of the tape on my LeMans. It's possible some plants used seam sealer.I don't see evidence that a screw was tightened in the #1 and #3 holes.
ID:	616023   Click image for larger version
The Following 2 Users Say Thank You to gto4ben For This Useful Post:
Old 07-15-2023, 07:58 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Interesting to learn that one of these holes on my car was actually done at the factory. I just assumed it was drilled by the original owner that used it to run two wires through it for the old Sun tach that he installed. The other holes do have the original cloth tape over them. Apparently Fremont used tape instead of sealer.
ID:	616129   Click image for larger version
The Following User Says Thank You to 428ho4spd For This Useful Post:
Old 07-16-2023, 12:07 AM
242177P's Avatar
242177P 242177P is offline
X2. Here's an early 66 example of four tape locations
(voltage regulator has partially hidden one)
The Following User Says Thank You to 242177P For This Useful Post:
Old 07-16-2023, 02:32 PM
Here’s more info. I mounted an old voltage regulator which requires the use of hole number 2. I will be filling holes 1 and 3. The 3 holes needed for the voltage regulator are labeled VR in the photo.
ID:	616167   Click image for larger version
Terry Hunt
Old 07-16-2023, 03:41 PM
I measured the witness marks from the cloth tape residue. It's about 1.25" long x 0.5" wide. I made some cutouts out of painter's tape to precisely apply the contact cement on the firewall and applied the cut cloth over the holes.
BTW, I think the hole in the center of the firewall may have been used for the underhood lamp. Can someone with an underhood lamp confirm this?
ID:	616187   Click image for larger version
The Following User Says Thank You to gto4ben For This Useful Post:
Old 07-16-2023, 05:19 PM
looks like friction tape was used
or seam sealer depending on plant
Old 07-16-2023, 06:11 PM
428ho4spd's Avatar
Nice job, Ben. I see they used longer pieces of tape on earlier builds prior to my car which has more square cut pieces, a cost cutting measure I'm sure.
Old 07-16-2023, 06:18 PM
428ho4spd's Avatar
Here's a photo of a Fremont built survivor with an underhood lamp.
The Following 2 Users Say Thank You to 428ho4spd For This Useful Post:
Old 07-19-2023, 02:43 PM
I have the same configuration/same location in the center of the firewall as yours Ben. A hole on right and a dimple on the left below the lamp in 428's photo. Not sure if those bolt heads shown in his photo are holding the lamp in place or some other component? According to his photo, looks like the lamp is mounted above the seam but maybe the bracket is painted black hiding the bracket which is actually attached below the seam?
Old 07-19-2023, 02:54 PM
428ho4spd's Avatar
Hard to see in that photo, but the bracket is mounted below the seam. And the lamp is bent upward slightly on this car which makes it deceiving. I'll zoom in on the photo and attached it again here. I found a photo of another '67 survivor that I have in my files that I'll attach as well.
ID:	616383   Click image for larger version
