I acquired a 68 QJet Part Number 7028262 B8 VC - originally thought it was a 69 and planned on keeping it for the bird. It was in operating condition when I received it a couple of years ago. All linkage moves freely. What’s she worth?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Is this a Price is Right question? $1.00 Sorry I'm a west coast guy up late.
DragStarLeMans |
Your carb is a "remanufactured" Frankencarb with a Carter made 7028262 float bowl and Buick airhorn and Buick throttle plate.
These kind of carbs usually have issues that takes a book to describe. Value is in individual parts if you know what to look for, as a carb next to nothing i´m afraid. |
The Following 4 Users Say Thank You to Kenth For This Useful Post: | ||
Thanks- look forward to additional responses. Educate me - how do you know it’s a mix of parts?
Well, LOTS of tell-tale signs of being a miss-match of parts. Buick throttle shaft/baseplate. Buick choke parts, 3/8" PCV vacuum tube used as a front vent. 2GC check ball retainer driver into the hole at the top of the choke tower in the airhorn.
It's also a Carter casting, not Rochester. They don't hold up quite as well from that time period and almost 100 percent of them will need a heli-coil for the fuel filter housing and many have already had the dreaded double "O" ring N/S instead of the screw in varity. I wouldn't even work on those here when I still had the shop open doing carburetors. Lessons in humility await those who venture in that direction.......FWIW
The Following 5 Users Say Thank You to Cliff R For This Useful Post: | ||
Thanks .
I was planning on rebuilding this 17058241 carb - is it a mix of parts as well?
More pics of the 17058241:
I don't know how to recognize the Frankencarbs like Kenth and Cliff but I can tell you that it's a Buick carb. At least the throttle plate. They have that funky, bent looking throttle arm. Actually, I would think that would be a pretty good one to build according to one of Cliff's recipes. I have one on the shelf myself. One good thing is the inlet being on the front like Pontiac.
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 12-02-2023 at 12:36 PM. |
The Following User Says Thank You to Greg Reid For This Useful Post: | ||
It looks about as original and unmolested as they come......
The Following 2 Users Say Thank You to Cliff R For This Useful Post: | ||
Great - thank you. It moves freely- once I get an engine together I will contact you for rebuild kit.
![]() Quote:
What's the chance you experts could create a "How to ID a Frankencarb" sticky? I learned a little but found it frustrating when, for example, I tried to use the casting part numbers to see if the body, airhorn, and throttle plate were "correct". I never found a listing... if this exists anywhere in Rochester or Delco literature, it would be a godsend. I did learn that any carb with a blocking tab has been through a rebuilder... |
The Following User Says Thank You to Shiny For This Useful Post: | ||
"Great - thank you. It moves freely- once I get an engine together I will contact you for rebuild kit."
Sounds great. We'll do a slight recalibration at the same time. I've built a lot of those and aside from the "goofy" linkage they make a great electric choke high performance unit.....
The Following User Says Thank You to Cliff R For This Useful Post: | ||
![]() Quote:
A better use of the casting numbers is the negative side. If a carburetor doesn't have a certain casting, it isn't what it is supposed to be; but just because it has the proper casting number is not a positive identification. A much more useful document would be a part number interchange, which Rochester actually printed........................................... .........in 1959! Have never seen a newer one. I have spent hundreds of hours, perhaps thousands of hours, working on one, but a long way from complete. Jon
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
The Following User Says Thank You to carbking For This Useful Post: | ||
![]() Quote:
I appreciate the casting numbers were machined per application and therefore not definitive. I also get your point about the "wrong" casting number being an obvious mismatch. I found it totally unexpected that each main part would not have a unique identifier after machining. I have no idea how they managed this in a factory but obviously they had a way. Interesting and again, unexpected, about the lack of a "published" interchange document. I guess without a unique identifier on the machined part, such a document would have limited value. Your list would be more like VERY valuable. I can't be the only one that's ever struggled to determine what he had or want to piece together a "correct" set of cast parts. Even being in the ballpark would feel like a home run after a couple hours of frustrating puzzle-solving. Mike |
