Old 01-20-2024, 02:05 AM
LET LET is offline
Default Pulleys 67 GTO
I’m restoring a 67 GTO. In preparation for installing add on air conditioner, classic air said I needed 3 groove crank pulley and 2 groove water pump pulley. I bought them and installed them today and I don’t think they look right. BTW, I plan on installing power steering. Can you guys tell me if the pulleys look correct?
Old 01-20-2024, 06:36 AM
Kenth's Avatar
Kenth Kenth is offline
Pulleys OK, timing cover and W/P wrong.
You will need a 1966-67 timing cover and a 1964-68 W/P.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-20-2024, 10:01 AM
LET LET is offline
Thanks Kenth,
I appreciate your response! Is there any problem with a used timing chain cover?
LET
Old 01-20-2024, 04:50 PM
geeteeohguy's Avatar
Originally Posted by LET View Post
Thanks Kenth,
LET
Original covers are a perfect fit. Make sure it's not pitted/eroded/corroded. JB weld can help in these areas if needed. I coat the inside of my timing covers and divider plates with Glyptal to keep electrolysis at bay.
Jeff
Old 01-20-2024, 07:46 PM
The bottom pulley is not a 3 groove pulley but a single groove AC pulley and a 2 groove pulley for alt. and PS separated by a large rubber donut.
Old 01-21-2024, 07:19 AM
rockdoc's Avatar
rockdoc rockdoc is offline
Jeff, which of the many Glyptal products do you use? I visited their web site after reading your post, and I see that they have dozens of different products. Does the Glyptal last well in that environment?
Dave
Old 02-02-2024, 07:27 PM
GTOh!'s Avatar
GTOh! GTOh! is offline
Thanks for posting, LET. Looks like a big but fun project.
Can someone comment on the pulleys’ finish? I see these are painted black but I’ve seen a concours restoration that showed at least the water pump pulley and the alternator pulley in the gold colored plating.
