Old 02-28-2024, 07:31 PM
Kevin Kevin is offline
Default 455 hyd roller cam?
Hi everybody,
Going thru my old parts stash a found a comp hyd roller cam with a 3315/3317(230/242@.050”) on a 114 LSA grind. How would this work on a 455 with 9.8:1 CR and ported d ports?
Thanks,
Kevin
Old 02-28-2024, 07:32 PM
tom s tom s is offline
If I had it I would run it,no ideas what other will say.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 02-28-2024, 08:04 PM
Steve C. Steve C. is online now
Very similar to Butler custom except with an additional 6 degrees exhaust duration. They are COMP XE lobes.
https://butlerperformance.com/i-2936...tegory:1459686
It's the Comp XR288HR but instead of a 110 LSA its custom ground with the wider 114 lobe separation.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 02-28-2024, 08:54 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I`d run it. Especially in a heavier street car.
Old 02-28-2024, 09:58 PM
Tim Corcoran's Avatar
Should make great power, have decent vacuum and a steady idle especially with a 114 LSA. If you have an auto trans it should have a 2500 stall converter for best performance.
Tim Corcoran
Old 02-29-2024, 07:38 PM
Thank you everyone, I appreciate your input!
Kevin
