Old 03-03-2024, 06:53 PM
ejgoat ejgoat is offline
Default Hood emblem
How do you get to the nuts on a front hood emblem on a 64 goat,
Old 03-03-2024, 06:54 PM
Default Hood emblem
How do you replace the hood emblem on a 64 goat, can,t find a way in to the nuts
Old 03-04-2024, 03:03 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Try a search for this question, I believe I asked a while ago. Answer was it only has 1 nut on inside, under the hood secondary latch.
64 Lemans hardtop
4spd, buckets
Old 03-04-2024, 04:26 PM
bill ryder's Avatar
bill ryder bill ryder is offline
That is right. There is one hex nut you can get to. The other post uses a barrel nut. After you remove the hex nut, you will probably still have to pry straight up gently to get the barrel nut to release. Don't get to mean with it or the second post will break off.
"Bill"!
https://forums.maxperformanceinc.com...emblem+removal
good link
