Old 04-12-2024, 12:14 PM
1950Mercury 1950Mercury is offline
Default 66 GTO hood bump stops
Can someone tell me if on the core support there is a nut welded in the hole for this hood stop stud or is it a push in speed nut like the one pictured? I am thinking I may have a aftermarket support because I only have a hole and no sign of broken welds. 66 GTO
Old 04-12-2024, 05:24 PM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
I hope this is what you are looking for? The rubber bumper?
https://forums.maxperformanceinc.com...1&d=1712956860
Fort Worth/Dallas TX area
1966 GTO Fontaine Blue
389 CID Carter AFB
Muncie 4 speed (orginally an automatic car)
Old 04-12-2024, 05:52 PM
I do know what they look like and where they go. I need to know if what they go into has a welded in nut or if it has a clip sort of like the pic. I posted. My hole is just a hole without a thread to screw these into.
Old 04-12-2024, 09:58 PM
fyrffytr1's Avatar
I wish I could help you, but my car is a 67 and it is locked up in a building at our local Fair Grounds for a car show. I can look tomorrow morning and report back tomorrow evening if no one else chimes in. I am pretty sure it is a welded nut.
Old 04-12-2024, 11:10 PM
I'm thinking you may be right but please let me know for sure though. You wouldn't happen to be at the Spokane Washington show by any chance?
Old 04-13-2024, 12:35 AM
242177P's Avatar
242177P 242177P is offline
Just checked two supports, at a glance the underside
looks like a common nut with no weld to be seen. But
there's a circular parting line on the topside, so the nut
appears to be a weld nut?
Old 04-13-2024, 12:32 PM
Thank you. And of course a person would never find a nut kike that. Looks like it's time for a riv nut.
Old 04-13-2024, 10:26 PM
fyrffytr1's Avatar
No, I am in Leesburg, Georgia. And, the nut is definitely welded to the underside of the core support. I can't get a picture of it, but I was able to run my hand up under and feel it. There was no cage around it, just the nut. There is a jam nut on the threaded hood bumper that tightens it up once adjusted.
Old 04-13-2024, 10:37 PM
fyrffytr1's Avatar
https://www.albanycountyfasteners.co...p/8100-008.htm
https://www.mcmaster.com/products/weld-nuts/
The Following User Says Thank You to fyrffytr1 For This Useful Post:
Old 04-14-2024, 05:20 AM
Kenth's Avatar
Kenth Kenth is offline
I think this is what you are looking for, at least itīs what i have seen used on an original 1966 GTO core support:
https://www.amkproducts.com/bulk-fas...forlookup=7135
Name:	Core support weld nut.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-14-2024, 07:47 PM
I was sure hoping it wasn't a weld in.
Old 04-15-2024, 05:53 AM
Jeff Hamlin's Avatar
X2 on OE being welded.
Old 04-15-2024, 01:17 PM
Oh well. I installed riv nuts yesterday. That's what you do when some idiot don't weld a nut on backside.
The Following User Says Thank You to 1950Mercury For This Useful Post:
Old 04-15-2024, 05:15 PM
fyrffytr1's Avatar
You do what you gotta do!
