1979 trans am. Does anyone know where the headlight get power from ? Thanks
Headlight switch
Essentially off the post on the rear of the alternator.
1977 Trans Am 400/4speed (swap) Brian |
The front harness supplies power to the headlights. It connect to the fuse box through the firewall. Are you having a Headlight issue?
The fuse box is built like a receptacle. An inner and an outer.
Usually just a bolt or two removed from firewall side , and the firewall side of the wire harness will come unplugged from fuse box. I lost headlights and some other associated things in my van once - without any notice. Had some bad corrosion inside when unplugged harness from fuse box. |
