Old 07-24-2024, 05:44 PM
Jeff Hamlin's Avatar
Arrow WANTED: 1966-67 HEATER HOSE SUPPORT BRACKET.
This bracket was used on models with Air Conditioning.
I know A-Bodies for sure,
F-Body, I'm not sure.
Let me know if you have one to sell. Thanks!
Old 01-02-2025, 07:14 PM
Still Looking.
Old 03-07-2025, 06:15 AM
Smile
Still on the hunt..
Old 06-07-2026, 05:49 PM
Exclamation THE HUNT IS OVER
I think I've been looking for this little Bracket on and off for well over 10 Years
Thank you Chris for remembering about my quest.
I owe you Brother!!
Old 06-07-2026, 09:08 PM
Cammer-6 Cammer-6 is offline
looks easy enough to fab up
3D print a set of dies
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 06-08-2026, 05:28 AM
Yea my printer doesn't do 3D
Made one out of flat stock years ago but nowhere near as detailed as OE.
Name:	HEAT HOSE SUPPORT-5.jpg
Old 06-08-2026, 11:14 AM
Jeff when someone bends over to look at your copy,and says something about it,
do as Red Forman says,"how would you like my foot up your ass?"
Old 06-08-2026, 11:22 AM
I just checked,and the Sprint Im currently disassembling for restoration still has said bracket attached.
So that means me constantly moving the car has paid off,and Jeff hasnt found it yet.
I have parted out a few OHC-6 with AC so perhaps I have one stashed somewhere. I ll look when I have a chance.
Old 06-08-2026, 11:46 AM
Post #4 says "The hunt is over", so I think he found one.
The Following User Says Thank You to TXSTARFIRE For This Useful Post:
Old 06-08-2026, 12:12 PM
for some reason I took that as someone had finally found one to photograph
Old 06-08-2026, 06:11 PM
No it's mine
Old 06-09-2026, 09:28 AM
Thumbs up
good deal,it wouldnt be pretty with me trying to find one in all this stuff.
Old 06-14-2026, 06:54 AM
Soaked off all the crud...
Old 06-14-2026, 09:45 AM
Jeff,have you tried dipping small parts to repaint?
Use catalyzed Rustoleum.
So that you dont waste a lot of catalyzed paint,pour paint in a container about 2x as deep as your part,
that was filled with water first.
The paint will float on the water.
Slowly dip the part thru the floating paint film.
Once the part is completely coated slowly pull it back thru,hang to drip dry.
Old 06-14-2026, 03:53 PM
I figured it took so long to find this little SOB I would make it standout as much as possible.
Cast Iron Heat Coating was my choice
Old 06-14-2026, 04:06 PM
hummmm ribbed heater hose
good job
