Old 08-05-2024, 08:09 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default Electrical Help Needed
Hey guys
So during the maiden voyage of my newly purchased 67 LeMans to Norwalk, the guys noticed when I had my left turn signal on that my brake lights didn’t work on either side. But with that right signal on they do.
I have replaced bulbs twice but don’t understand how one side can work and the other not. All other lights and scenarios work correctly, any ideas what to look for? I’m assuming there’s a short to ground but since the rear harness is all together I’m at a loss for where to start.
Joe
Old 08-05-2024, 08:57 PM
What do the front turn lights do?
Old 08-05-2024, 09:12 PM
ponchjoe's Avatar
Hey John, the fronts work in all scenarios
QUOTE=johnta1;6518923]What do the front turn lights do?
[/QUOTE]
Old 08-05-2024, 09:46 PM
The left signal light up but no brake light or no light on left at all?
Left works OK without brake pushed?
Old 08-05-2024, 10:13 PM
ponchjoe's Avatar
With key on or off, I have all brake lights. With key on I have right turn signal and brake lights, with key on I have left turn signal and no brake lights on either side.
Old 08-06-2024, 06:33 AM
When you changed bulbs was it both sides or just one side?
I'd start by checking the right side (or both sides really) for good ground on sockets. The bulbs are correct bulbs I figure, but check anyway.
Swap bulbs from one side to other side and see if it is the same.
(might even take one bulb out at a time and see what it does?)
If nothing, then may be the turn signal switch?
Probably one of those things that are hard to sleuth over internet.
Old 08-06-2024, 10:07 AM
george kujanski's Avatar
If the bulbs and grounds are good, bulbs installed correctly, the prob then is most likely the turn signal switch.
George
The Following 2 Users Say Thank You to george kujanski For This Useful Post:
Old 08-06-2024, 10:30 AM
Try wiggling the turn signal lever with left turn on. If you get a flicker out of right brake the turn signal switch needs some TLC or replaced.
Clay
PS this test should work with ignition off or on
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post:
Old 08-06-2024, 01:10 PM
ponchjoe's Avatar
You nailed it. With brakes on and left signal on if I pull up just a tiny bit the brake lights comes back on
Clay
Old 08-06-2024, 07:42 PM
ponchjoe's Avatar
We have a winner. Looks like some good old backyard modifications.
Think I’ll replace it 😆
The Following User Says Thank You to ponchjoe For This Useful Post:
Old 08-06-2024, 09:19 PM
ponchjoe's Avatar
Is this the correct switch for this car? Looking at Ames catalog they call out a floor shift switch as a p/n M140GR but it does not have the springs which are on the M140FR. This switch however says it fits column shift MT cars.
My car is pretty original and was built as a floor shift auto car.
Any help is appreciated
