Took a little cruise pulled in the garage and noticed a sound that seemed like rod knock.Noticed this crack on the lower pully
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
Very lucky you were able to get it home before it failed all the way and took out your radiator.
| The Following User Says Thank You to steve25 For This Useful Post: | ||
That’s sure aggravating but better than something internal.
| The Following User Says Thank You to PontiacHO For This Useful Post: | ||
If you need a replacement I have like 6 of them, if you post the part # I'll take a look.
Dont mean to hijack this thread but having a hard time removing my lower pulley. It wouldnt pull off the balancer once I removed the four screws. Even the reinforcing ring wont come off. I currently have the balancer, pulley and reinforcing ring off the engine all as one unit, none of which will seperate. Any ideas?
Thanks DV |
Sounds like it’s all rusted together .
If it’s not too badly cracked then Put the bolts back in Put the belts back on and tighten them up Then back the bolts out 1/16” and start the motor. The load force my be enough to bust it free. If not then it time to drive a big ass chisel or pry bar behind the pulley to split it free off the face of the balancer.
Thanks yahoo pn is 481038yb I really don't think it would be safe to reweld this.I need one like yesterday ,going to the track Sat.Thanks in advance
Thks Steve. It looks like chisel is coming out as engine is out of car for a dipstick tube replacement. If you get bored pls wander over to the heating and cooling section for my water pump question as I have had a lot of looks but no replies.
DV |
Can this pulley be repaired by welding temporarily so I can race it ?
Just answered my own question about welding, after some more sanding around bolt holes.When was the last time you checked your lower pulley?
Looks also like rust pitting was involved in the start of the crack.
Did you have the support washed spacer in place when it cracked?
Yes and all bolts were tight when removed.Support bracket was installed in front of pulley
Heres what I have.
I wouldn’t weld it but if you do be sure to drill holes at the ends of the cracks
The More People I Meet, The More I Love My Dogs! |
