Old 08-22-2024, 10:28 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default Correct Air Cleaner painting
Hey guys,
I recently picked up a rare 67 326 HO air cleaner that needs restored. What’s the best to use on it since it is in a high heat area? Also what sheen should it be, semi gloss?
Joe
Old 08-23-2024, 05:38 AM
Jeff Hamlin's Avatar
I would say SEMI Gloss for sure.
Most OE Breathers don't seem/appear Glossy.
I use both Dupli-Color Engine Paint and/or VHT FLAMEPROOF High Temp Paints for engine bay items.
Old 08-23-2024, 09:57 AM
ponchjoe's Avatar
Thanks for the reply Jeff, I’ll look at the engine paints and trial spray.
Do you know if anyone is recreating the information stamped on the side?
The Following User Says Thank You to ponchjoe For This Useful Post:
Old 08-23-2024, 11:53 AM
68bird400HO's Avatar
Air cleaners are usually 90% gloss black. Rattle can gloss black will get you pretty close. VHT makes a great paint.
The Following 2 Users Say Thank You to 68bird400HO For This Useful Post:
Old 08-23-2024, 12:10 PM
Here’s a good example of factory air cleaner paint.
Semigloss not at all, 90% or maybe gloss black.
https://forums.maxperformanceinc.com...d.php?t=873080
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 08-23-2024, 02:30 PM
gto4ben gto4ben is offline
These are California 326HO Air cleaners. The cleaner one is towards the glossy side.
ID:	638786   Click image for larger version
ID:	638787   Click image for larger version
The Following 2 Users Say Thank You to gto4ben For This Useful Post:
Old 08-24-2024, 05:52 AM
Thumbs up Good Info;
Thanks, Guys for the clarity/correction. I've not had any OE-painted Breathers in Years.
