Old 08-30-2024, 02:58 PM
spartazoo's Avatar
spartazoo spartazoo is offline
Default Caution - 66-70 POR 15 Engine Paint
If you are considering an engine paint or repaint, think twice before ordering the POR 15 metallic blue engine paint kit, it is GREEN not blue!
I opened the can and closed it back up. I will be contacting POR15 to get their feedback.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
The Following User Says Thank You to spartazoo For This Useful Post:
Old 08-30-2024, 09:46 PM
I think InlineTube and Ames are the only ones left with a correct shade.
Not sure if they sell pints/quarts - but you can check online.
Old 08-30-2024, 10:28 PM
Redpiston Redpiston is offline
What about using POR for a base coat and then top it with the ames product?
Isn't the ames product by eastwood?
Old 08-30-2024, 10:43 PM
Pretty sure Ames gets it from InlineTube , or same supplier.
They had a formula made to their specs for it , and other years.
Not just regular production shelf products that have a take it or leave it color result.
Old 08-30-2024, 11:52 PM
chevymad chevymad is offline
I'd put a dab on something and see what color it dries to.
Old 08-31-2024, 08:11 AM
Half-Inch Stud's Avatar
Was it like Johnson outboard green and 68 buick ? Is nice if so.
Old 08-31-2024, 10:47 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Caution if using POR15, if you spill antifreeze on POR15 engine plant it will stain the paint. Did a small block a while ago, about a year after the painting
I blew a rad hose clamp and popped off the top hose at t. stat housing, green antifreeze all over engine. Washed it off within ten minutes but it had
stained a lighter shade. Was not happy. Although it does cover nicely and looked good until the antifreeze issue. Not a Pontiac colour though.
64 Lemans hardtop
4spd, buckets
Old 08-31-2024, 03:35 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Does Ames/Inline Tube have an actual accurate GM Corporate Blue for mid to late 70's engines?
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 08-31-2024, 04:06 PM
KS circutguy's Avatar
Most,if not all engine enamels will stain if coolant get on it with a hot engine.
The Following User Says Thank You to KS circutguy For This Useful Post:
Old 08-31-2024, 11:00 PM
Yes.
Inline has all colors matched from 59-81
12oz cans @ $10 each.
Custom mixed house brand - not store shelf stuff.
Ames only shows Dupli-Color brand for 66-70
It is too blue , many discussions regarding matching 66-70 Silver Blue in the past.
https://www.inlinetube.com/products/inl15375
Here is a list for Ames house brands
10 oz @ $19 each
https://www.amesperf.com/parts/searc...m=Engine+paint
Old 09-01-2024, 10:40 PM
fyrffytr1's Avatar
Bill Hirsch makes excellent paint
https://www.hirschauto.com/ENGINE-EN...%20M%20BL%20E/
