Old 08-31-2024, 02:48 PM
Rar_421 Rar_421 is offline
Default Dci aluminum ra 4 heads
I saw some pics on Facebook this morning of some heads from Dci that are prototypes on the way to be machined with casting numbers 48,614 and 722,I didn't see the ports on the 614's and 722's but the 48's were Dport,he will have more info on his pod cast Wednesday night
The Following User Says Thank You to Rar_421 For This Useful Post:
Old 08-31-2024, 03:15 PM
grandam1979 grandam1979 is offline
I saw that also are they aluminum or cast?
Old 08-31-2024, 03:28 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I saw a post here yesterday with a pic
http://forums.maxperformanceinc.com/...d.php?t=875802
The Following User Says Thank You to ponchjoe For This Useful Post:
Old 08-31-2024, 03:42 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
That would actually be a nice market niche to fill. The Small Block Chevy crowd gets to enjoy reproduction factory heads with stock flow characteristics and chamber size, only difference being made in aluminum in order to benefit from weight savings and better thermal conductivity. Would be nice for people that want to do milder builds but don't want to fork out the $$$ for higher performance heads.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 08-31-2024, 03:45 PM
Look to be aluminum from the pics
Old 08-31-2024, 03:51 PM
From his post in FB these are stock appearing externally but with improvements inside, I'll be watching his podcast weds
His latest post says 45 degree seats and shooting for 300 +cfm
The Following 2 Users Say Thank You to Rar_421 For This Useful Post:
Old 09-01-2024, 09:06 AM
Formulajones's Avatar
It's about damn time. I'm on board for a set. I've been saying for years they need to make copies of 614's/722's in aluminum that mimic the appearance of the factory offerings.
https://youtu.be/XqEydRRRwqE
Old 09-01-2024, 09:10 AM
Actually they are drastically different in flow than the factory stuff. I have a set. Trick Flow has been making copies of hump heads for years, and doing a really good job at it. Paint them orange and they fool everyone.
Out of the box as cast they flow between 260-270 cfm and are only a 170cc head, worlds better than a factory hump head that if you're lucky might flow 200-210 cfm, and that's a big valve version.
Trick Flow also incorporates a more modern heart shaped chamber. They are super nice pieces for a stealth build
Hoping these new RAIV aluminum heads follow the same path, if so I'll be picking up a set.
Old 09-01-2024, 10:25 AM
PAUL K's Avatar
PAUL K PAUL K is offline
......and the paint won't burn off the exhaust ports.
Go fast, see Elvis!
Old 09-01-2024, 12:25 PM
adamo adamo is offline
I really hope I can get my hands on a set of the 722’s if they do become available. Does anyone know when we will get more info on these?
Old 09-01-2024, 01:55 PM
PAUL K's Avatar
A lot of folks express interest in these heads.... I'm curious at what price point does your interest wane?
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 09-01-2024, 02:15 PM
72projectbird's Avatar
If they're similarly priced to Edelbrock or Kauffman heads, I'm going with either of those two.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
The Following 3 Users Say Thank You to 72projectbird For This Useful Post:
Old 09-01-2024, 02:37 PM
I would imagine they’re going to be priced similarly to competing aluminum aftermarket heads with similar specs.
And why would anyone expect them to be significantly less expensive than the current offerings from Kaufmann or Edelbrock?
Here you have yet another choice of a high flowing modernized combustion chamber aluminum head with a different look that might be more in line with what many buyers with hot street cars would prefer.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 09-01-2024, 02:57 PM
67drake's Avatar
67drake 67drake is offline
Questions
I’ve never owned Kaufman or E heads. Can you bolt factory brackets to them?
I assume these will accommodate factory brackets for guys who want to keep it stock looking under the hood. (Like me)
‘55 Catalina
Old 09-01-2024, 03:54 PM
67Lemons 67Lemons is offline
These are exciting, it’s about time someone makes a standard looking head for those of us wanting to retain a stock look under the hood!
Old 09-01-2024, 04:05 PM
PAUL K's Avatar
Pontiac made millions of them.
Go fast, see Elvis!
Old 09-01-2024, 04:43 PM
Dragncar Dragncar is offline
Well, if they are priced "less" than the Edelbrock heads, which they should be as Eddy has been charging us extra for decades then these will sell. A lot IMO.
Maybe they will be priced around the same, small batch stuff ?
But it is so nice to see this. If they can really go 300cfm as cast, more than a E head, look stock, we have a winner !
Hope they have more materiel in the right places so someone can wide port them. Maybe get some without the pushrod holes drilled.
I see no shortage in Pontiac guys wanting to buy heads like these.
He will sell far more of these than RAV heads.
Thanks Don.
Old 09-01-2024, 04:46 PM
mgarblik mgarblik is offline
I noticed there is no provision in the casting for spark plugs. Not that it is needed. But that may open up options for straight or angle spark plugs. All the modern chambers I am aware of use angle plugs. That would ruin the looks for some folks. Angle plugs are an easy give away for those in the know. I have a pair of Edelbrock D-ports with all the markings off them painted blue. About 1 in 100 at a show may pull a magnet or notice the angle plugs.
Old 09-01-2024, 04:47 PM
Originally Posted by 67drake View Post
Questions
I know on High Ports one of the 3 bolt holes for the alternator bracket was deleted. I found a way around it for my situation where I kept the factory alternator mount.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 09-01-2024, 04:53 PM
Stevie Wonder could tell those castings are much cleaner looking than any cast iron factory head, they’re not going to fool anyone once they’re painted.
Angle plugs should be incorporated surely, making them straight plugs makes absolutely zero sense.
A nice looking head for sure and it will make the more purist type of performance guy happy, but if it offers nothing more than a casting number and to mimic the look of a factory head over their competition then they’ll miss the mark.
